I’m moving my second zwave network (different location) from Vera/Micasaverde to OpenHAB. I am having problems with several mains-powered devices not creating xml files even after leaving the network to heal/query for several days. Things I’ve tried to no avail: reinstalled raspbian and openHAB from scratch, deleted controller and re-included devices, and deleted all zwave things from openHAB and re-added them.
Nodes 3, 4, 8, 10, 11, and 12 show as unknown (tho the devices are in the database) and do not generate xml files, which is what I find the most strange. All of the “missing” devices are light switches right next to others which are being discovered just fine.
Things seem to be going wrong on Version_Command_Class_Get, but I am having a difficult time interpreting the log, even with @chris 's helpful viewer. I am at a total loss and hope that someone can read the tea leaves of my debug logs. =/
vzorglub
(Vincent Regaud)
June 9, 2018, 8:12pm
#2
Can you show the tea leaves, please?
Sure thing. The forum disallows .log or .txt uploads, so is a dropbox link okay?
openhab.log
chris
(Chris Jackson)
June 9, 2018, 8:44pm
#4
SmoochiesBoss:
What are the devices? I’ve seen this issue before where the device isn’t responding to a basic request which it should. This is preventing the device from completing initialisation.
This was for node 3 at least - are they all the same device?
They’re all similar devices, Leviton Vizia rf dimmers of a few different model flavors (MLV, ELV, incandescent).
E
chris
(Chris Jackson)
June 9, 2018, 9:00pm
#6
I can’t work out what devices they are in the database - can you provide the links to the devices from my website ?
chris
(Chris Jackson)
June 9, 2018, 10:34pm
#8
Thanks. One last question - do you have a similar device that is working?
I’m reasonably sure I’ve seen this issue before so if I can simply copy the config I used previously, it may avoid some iterations…
The below is another, similar Leviton, I think–unless I’ve been looking at this for too long and I’m choosing the wrong node… I’m not sure what’s going on with the GE device.
<node>
<deviceClass>
<basicDeviceClass>ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>MULTILEVEL_SWITCH</genericDeviceClass>
<specificDeviceClass>SCENE_SWITCH_MULTILEVEL</specificDeviceClass>
</deviceClass>
<homeId>0xe306decb</homeId>
<nodeId>6</nodeId>
<version>4</version>
<manufacturer>0x1d</manufacturer>
<deviceId>0x334</deviceId>
<deviceType>0x602</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<nodeInformationFrame>
<commandClass>SWITCH_MULTILEVEL</commandClass>
<commandClass>SWITCH_ALL</commandClass>
<commandClass>SCENE_ACTIVATION</commandClass>
<commandClass>SCENE_ACTUATOR_CONF</commandClass>
<commandClass>ASSOCIATION</commandClass>
<commandClass>MANUFACTURER_SPECIFIC</commandClass>
<commandClass>VERSION</commandClass>
<commandClass>MANUFACTURER_PROPRIETARY</commandClass>
<commandClass>NODE_NAMING</commandClass>
<commandClass>POWERLEVEL</commandClass>
</nodeInformationFrame>
<supportedCommandClasses>
<entry>
<commandClass>BASIC</commandClass>
<basicCommandClass>
<version>1</version>
<instances>1</instances>
<versionSupported>1</versionSupported>
<isGetSupported>true</isGetSupported>
</basicCommandClass>
</entry>
<entry>
<manufacturerSpecificCommandClass>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>29</deviceManufacturer>
<deviceType>1538</deviceType>
<deviceId>820</deviceId>
</manufacturerSpecificCommandClass>
</entry>
<entry>
<multiLevelSwitchCommandClass>
</multiLevelSwitchCommandClass>
</entry>
<entry>
<commandClass>NO_OPERATION</commandClass>
<noOperationCommandClass>
</noOperationCommandClass>
</entry>
<entry>
<commandClass>APPLICATION_STATUS</commandClass>
<ZWaveApplicationStatusClass>
<version>0</version>
<instances>0</instances>
<versionSupported>0</versionSupported>
</ZWaveApplicationStatusClass>
</entry>
<entry>
<associationCommandClass>
<maxGroups>1</maxGroups>
</associationCommandClass>
</entry>
<entry>
<nodeNamingCommandClass>
<name></name>
<location></location>
</nodeNamingCommandClass>
</entry>
<entry>
<commandClass>HAIL</commandClass>
<hailCommandClass>
</hailCommandClass>
</entry>
<entry>
<switchAllCommandClass>
<mode>SWITCH_ALL_INCLUDE_ON_OFF</mode>
</switchAllCommandClass>
</entry>
<entry>
<powerLevelCommandClass>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</powerLevelCommandClass>
</entry>
<entry>
<sceneActivationCommandClass>
</sceneActivationCommandClass>
</entry>
<entry>
<versionCommandClass>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>3.52</protocolVersion>
<applicationVersion>0.7</applicationVersion>
</versionCommandClass>
</entry>
<entry>
<sceneActuatorConfigurationCommandClass>
</sceneActuatorConfigurationCommandClass>
</entry>
</supportedCommandClasses>
<securedCommandClasses/>
<associationGroups>
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<associations>
<associationMember>
<node>1</node>
<endpoint>0</endpoint>
</associationMember>
</associations>
</associationGroup>
</entry>
</associationGroups>
<nodeNeighbors>
<int>9</int>
<int>10</int>
<int>11</int>
<int>12</int>
<int>13</int>
<int>14</int>
<int>15</int>
<int>16</int>
<int>17</int>
</nodeNeighbors>
<lastSent>2018-06-09 19:44:58.504 UTC</lastSent>
<lastReceived>2018-06-09 19:44:58.636 UTC</lastReceived>
</node>
