Platform information:
Hardware: _Raspberry Pi 3 Model B Rev 1.2/1gb/16gb
OS: openhabian (very current)
Java Runtime Environment: which java platform is used and what version
openHAB version: 2.5.1-2
Issue of the topic: I’m learning how to use this and have settled on zwave sensors for some of the new stuff, and am sticking to known-operable devices and planning out how to populate my network, populating it, then making the interfaces pretty.
Zwave stick: Zooz S2 stick (zst10). I have no encrypted device.
I have installed a Stelpro Zwave heater controller (node 5), and it’s working well. Other successful (non zwave) adds are tplink switchable outlets, Chamberlain garage doors, and a haiku fan.
I’m using two HomeSeer HS-FS100+ flex sensors with flood detector cable.
Both flood sensors were setup, and paired successfully according to instruction - nodes 7 and 8. One is operating pure battery, the other powered, for testing. These are the “5 parameter” version (some apparently 4?), supposedly patched properly in 2.5 and I should have the fixes. The openhab device description/configuration has the correct corresponding parameters in the documentation for the device’s cheat sheets.
The devices pair, but beyond that, they seem inoperative. The sensor_temperature is always null, and I get errors when I try to push the one modifiable switch by both Paper and HabPanel.
What I’ve done is restarted openhab with a new log file, which I’ll add at the end, waited for it to come up, and then tried to flip the switch. This is why I think something’s going wrong (grepped out of the logs):
The device I’m trying to tickle is NODE 7. NODE 8 is the other HS FS100+, 6 is the stelpro.
2020-02-15 22:27:54.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 7: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2020-02-15 22:27:54.127 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 7: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2020-02-15 22:31:00.753 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Command received zwave:device:db38487f:node7:switch_binary --> ON [OnOffType]
2020-02-15 22:31:00.755 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 7: Command class class COMMAND_CLASS_SWITCH_BINARY for endpoint 0 not found
2020-02-15 22:31:00.756 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: No messages returned from converter
Complete log from startup:
zwave.log (320.7 KB)
