Hi Chris,
thanks for your fast response.
i dont know which informations are really important for you, so i post the complete log for one vibration alarm:
2019-01-02 20:35:44.544 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: resetResendCount initComplete=true isDead=false
2019-01-02 20:35:44.545 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2019-01-02 20:35:44.545 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: SECURITY NOT required on COMMAND_CLASS_BASIC
2019-01-02 20:35:44.545 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 32: Received COMMAND_CLASS_BASIC V0 BASIC_SET
2019-01-02 20:35:44.545 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 32: Basic report, value = 0
2019-01-02 20:35:44.546 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2019-01-02 20:35:44.546 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 0
2019-01-02 20:35:44.546 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Commands processed 1.
2019-01-02 20:35:44.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@83edd37.
2019-01-02 20:35:44.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-01-02 20:35:44.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-01-02 20:35:44.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-01-02 20:35:44.605 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 20 0A 71 05 02 00 00 FF 07 00 01 02 4C
2019-01-02 20:35:44.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=32, callback=0, payload=00 20 0A 71 05 02 00 00 FF 07 00 01 02
2019-01-02 20:35:44.606 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=32, callback=0, payload=00 20 0A 71 05 02 00 00 FF 07 00 01 02
2019-01-02 20:35:44.607 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-01-02 20:35:44.607 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Application Command Request (ALIVE:DONE)
2019-01-02 20:35:44.607 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: resetResendCount initComplete=true isDead=false
2019-01-02 20:35:44.607 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2019-01-02 20:35:44.608 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: SECURITY NOT required on COMMAND_CLASS_ALARM
2019-01-02 20:35:44.608 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 32: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2019-01-02 20:35:44.608 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 32: NOTIFICATION report - 2 = 0, event=0, status=255, plen=1
2019-01-02 20:35:44.608 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 32: Alarm Type = BURGLAR (2)
2019-01-02 20:35:44.609 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2019-01-02 20:35:44.609 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_ALARM, value = 255
2019-01-02 20:35:44.609 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 32: Alarm converter processing NOTIFICATION
2019-01-02 20:35:44.610 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 32: Alarm converter NOTIFICATION event is 0, type OnOffType
2019-01-02 20:35:44.610 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 32: Alarm converter NOTIFICATION event is 0, channel alarm_access is not implemented.
2019-01-02 20:35:44.610 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 32: Alarm converter processing NOTIFICATION
2019-01-02 20:35:44.611 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Updating channel state zwave:device:ControllerUSB:node32:alarm_tamper to OFF [OnOffType]
2019-01-02 20:35:44.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Commands processed 1.
2019-01-02 20:35:44.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1fe2b54.
2019-01-02 20:35:44.613 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-01-02 20:35:44.613 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-01-02 20:35:44.613 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-01-02 20:35:44.677 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 20 03 20 01 FF 0F
2019-01-02 20:35:44.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=32, callback=0, payload=00 20 03 20 01 FF
2019-01-02 20:35:44.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=32, callback=0, payload=00 20 03 20 01 FF
2019-01-02 20:35:44.679 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-01-02 20:35:44.679 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Application Command Request (ALIVE:DONE)
2019-01-02 20:35:44.679 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: resetResendCount initComplete=true isDead=false
2019-01-02 20:35:44.680 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2019-01-02 20:35:44.680 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: SECURITY NOT required on COMMAND_CLASS_BASIC
2019-01-02 20:35:44.680 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 32: Received COMMAND_CLASS_BASIC V0 BASIC_SET
2019-01-02 20:35:44.680 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 32: Basic report, value = 255
2019-01-02 20:35:44.681 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2019-01-02 20:35:44.681 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 255
2019-01-02 20:35:44.682 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Commands processed 1.
2019-01-02 20:35:44.682 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3350d23a.
2019-01-02 20:35:44.682 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-01-02 20:35:44.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-01-02 20:35:44.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-01-02 20:35:44.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-01-02 20:35:44.761 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 20 09 71 05 02 FF 00 FF 07 02 00 AE
2019-01-02 20:35:44.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=32, callback=0, payload=00 20 09 71 05 02 FF 00 FF 07 02 00
2019-01-02 20:35:44.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=32, callback=0, payload=00 20 09 71 05 02 FF 00 FF 07 02 00
2019-01-02 20:35:44.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-01-02 20:35:44.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Application Command Request (ALIVE:DONE)
2019-01-02 20:35:44.763 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: resetResendCount initComplete=true isDead=false
2019-01-02 20:35:44.764 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2019-01-02 20:35:44.764 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: SECURITY NOT required on COMMAND_CLASS_ALARM
2019-01-02 20:35:44.764 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 32: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2019-01-02 20:35:44.765 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 32: NOTIFICATION report - 2 = 255, event=2, status=255, plen=0
2019-01-02 20:35:44.765 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 32: Alarm Type = BURGLAR (2)
2019-01-02 20:35:44.766 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2019-01-02 20:35:44.766 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_ALARM, value = 255
2019-01-02 20:35:44.767 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 32: Alarm converter processing NOTIFICATION
2019-01-02 20:35:44.767 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 32: Alarm converter NOTIFICATION event is 2, type OnOffType
2019-01-02 20:35:44.767 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 32: Alarm converter NOTIFICATION event is 2, channel alarm_access is not implemented.
2019-01-02 20:35:44.768 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 32: Alarm converter processing NOTIFICATION
2019-01-02 20:35:44.768 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 32: Alarm converter NOTIFICATION event is 2, type OnOffType
2019-01-02 20:35:44.768 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Commands processed 1.
2019-01-02 20:35:44.768 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 32: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3cd0dec3.
2019-01-02 20:35:44.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-01-02 20:35:44.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-01-02 20:35:44.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-01-02 20:35:50.162 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 16 0E 32 02 21 34 00 00 00 33 00 01 00 00 00 35 D5
2019-01-02 20:35:50.163 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=22, callback=0, payload=00 16 0E 32 02 21 34 00 00 00 33 00 01 00 00 00 35
2019-01-02 20:35:50.163 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=22, callback=0, payload=00 16 0E 32 02 21 34 00 00 00 33 00 01 00 00 00 35
2019-01-02 20:35:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
