ZWave binding updates
zwave
Tags: #<Tag:0x00007f01477cc640>
(Chris Jackson) #442
Sorry - you’ve probably posted this somewhere, but is there a description of your problem? I scrolled up a few days, but haven’t seen anything.
(Christoph Nagel) #443
@chris, the description is in the same post a few lines further down:
:slightly_smiling_face:
(Chris Jackson) #444
Ah - ok, from the way it was worded I thought you were referring to something above. No problem - just my (mis)understanding :slight_smile: .
I’ll take a look at the log
(Christoph Nagel) #445
Oh, yes, you’re right - sorry for the confusion … :upside_down_face:
(Chris Jackson) #446
It looks to me like the data is being transferred through ok after the device wakes up -:
Here we see a command to set the setpoint to 22 -:
The device wakes up almost immediately, and the command to set the temperature is sent, and read back, and the state updated. This all happens within 1/2 second of the wakeup.
This command gets received just fine, and is queued. The device doesn’t wake up before you send it another command, so this is overridden by the command above to set the temperature to 25.
Again, I don’t see any problem. I’m not sure what your wakeup period is - you don’t say you manually woke the device up at this time (5:43) so I assume this is the device waking up normally, which is fine.
Or maybe I miss something?
(Selter) #447
Just to make sure …
When updating oH 2.3 to 2.4: one has to do the update first - and after that remove z-wave things via Paper UI - right?
(SiHui) #448
Yes, in whatever sequence. You may also do it the other way around.
(Kris K) #449
Hi All
Ive factory reset all devices, deleted ALL things, deleted all the XMLs and still, using the latest Zwave snapshot issues.
This is with the Fibaro Dimmer FGD212.
The pairing works fine, the thing is online and the controller are online. I cannot set the LifeLine and this is reflected in the log as:
10-Jan-2019 10:17:00.484 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:08bf3c5b:node4:switch_dimmer1 --> OFF [OnOffType]
10-Jan-2019 10:17:00.511 [DEBUG] [.internal.converter.ZWaveMultiLevelSwitchConverter] - NODE 4: Command class SWITCH_MULTILEVEL not found when processing command on endpoint 1
10-Jan-2019 10:17:00.511 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: No messages returned from converter
10-Jan-2019 10:19:09.910 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update received
10-Jan-2019 10:19:09.911 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update set group_1 to controller (String)
10-Jan-2019 10:19:09.911 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Unknown association group 1
10-Jan-2019 10:20:35.837 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Command received zwave:device:08bf3c5b:node4:switch_dimmer1 --> ON [OnOffType]
10-Jan-2019 10:20:35.838 [DEBUG] [.internal.converter.ZWaveMultiLevelSwitchConverter] - NODE 4: Command class SWITCH_MULTILEVEL not found when processing command on endpoint 1
10-Jan-2019 10:20:35.839 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: No messages returned from converter
10-Jan-2019 10:22:12.586 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:meter_watts unlinked - polling stopped.
10-Jan-2019 10:22:12.588 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:switch_dimmer1 unlinked - polling stopped.
10-Jan-2019 10:22:12.589 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:switch_dimmer1 unlinked - polling stopped.
10-Jan-2019 10:22:12.590 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:meter_kwh unlinked - polling stopped.
10-Jan-2019 10:22:12.591 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:meter_watts unlinked - polling stopped.
10-Jan-2019 10:22:12.591 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:switch_dimmer1 unlinked - polling stopped.
10-Jan-2019 10:22:12.592 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:meter_kwh unlinked - polling stopped.
10-Jan-2019 10:22:12.593 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:switch_dimmer1 unlinked - polling stopped.
10-Jan-2019 10:26:01.604 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:switch_dimmer1 linked - polling started.
10-Jan-2019 10:26:01.605 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:switch_dimmer1 linked - polling started.
10-Jan-2019 10:26:01.605 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:meter_watts linked - polling started.
10-Jan-2019 10:26:01.606 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:08bf3c5b:node4:meter_kwh linked - polling started.
10-Jan-2019 10:28:05.744 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update received
10-Jan-2019 10:28:05.745 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update set group_1 to controller (String)
10-Jan-2019 10:28:05.745 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Unknown association group 1
Does anyone know why?
I’m also seeing issues on a Aeotec device still, but it seems to work (STUCK IN GET_CONFIGURATION)
None of these devices are Battery
10-Jan-2019 10:16:06.049 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 96
10-Jan-2019 10:16:06.050 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:08bf3c5b:node2:switch_dimmer to 96 [PercentType]
10-Jan-2019 10:16:06.050 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
10-Jan-2019 10:16:06.051 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@545251cc.
10-Jan-2019 10:16:06.897 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling...
10-Jan-2019 10:16:06.898 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling deferred until initialisation complete
10-Jan-2019 10:16:09.491 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Command received zwave:device:08bf3c5b:node2:switch_dimmer --> OFF [OnOffType]
10-Jan-2019 10:16:09.492 [TRACE] [.internal.converter.ZWaveMultiLevelSwitchConverter] - NODE 2: Converted command 'OFF' to value 0 for channel = zwave:device:08bf3c5b:node2:switch_dimmer, endpoint = 0.
10-Jan-2019 10:16:09.492 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Creating new message for command SWITCH_MULTILEVEL_SET
10-Jan-2019 10:16:09.493 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, endpoint 0
10-Jan-2019 10:16:09.493 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
10-Jan-2019 10:16:09.494 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
10-Jan-2019 10:16:09.494 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
10-Jan-2019 10:16:09.494 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Added 408 to queue - size 3
10-Jan-2019 10:16:09.495 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == true, frequentlyListening == false, awake == false
10-Jan-2019 10:16:09.496 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 2: Creating empty message of class = SendData (0x13), type = Request
10-Jan-2019 10:16:09.497 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0A 00 13 02 03 26 01 00 25 6D 88
10-Jan-2019 10:16:09.499 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling intialised at 86400 seconds - start in 1500 milliseconds.
10-Jan-2019 10:16:09.510 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
10-Jan-2019 10:16:09.511 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: TID 408: Transaction not completed
10-Jan-2019 10:16:09.526 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 109, Status = Transmission complete and ACK received(0)
10-Jan-2019 10:16:09.527 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Response processed after 30ms
10-Jan-2019 10:16:09.527 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: TID 408: Transaction completed
10-Jan-2019 10:16:09.528 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: notifyTransactionResponse TID:408 DONE
10-Jan-2019 10:16:09.528 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
10-Jan-2019 10:16:10.235 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 2: Message payload = 00 02 03 20 03 00
10-Jan-2019 10:16:10.237 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:GET_CONFIGURATION)
10-Jan-2019 10:16:10.237 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
10-Jan-2019 10:16:10.237 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
10-Jan-2019 10:16:10.237 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_BASIC V1 BASIC_REPORT
10-Jan-2019 10:16:10.238 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 2: Basic report, value = 0
10-Jan-2019 10:16:10.238 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
10-Jan-2019 10:16:10.238 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 0
10-Jan-2019 10:16:10.238 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:08bf3c5b:node2:switch_dimmer to 0 [PercentType]
10-Jan-2019 10:16:10.239 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
10-Jan-2019 10:16:10.239 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5cfbbb03.
10-Jan-2019 10:16:10.999 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling...
10-Jan-2019 10:16:10.999 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling deferred until initialisation complete
10-Jan-2019 10:16:32.805 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 2: ZWaveCommandClassTransactionPayload - send to node
10-Jan-2019 10:16:32.805 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: Encapsulating message, endpoint 0
10-Jan-2019 10:16:32.805 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
10-Jan-2019 10:16:32.806 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
10-Jan-2019 10:16:32.806 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@68289a35
10-Jan-2019 10:16:32.807 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
10-Jan-2019 10:16:32.807 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Added 409 to queue - size 3
10-Jan-2019 10:16:32.808 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == true, frequentlyListening == false, awake == false
10-Jan-2019 10:16:32.809 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 2: Creating empty message of class = SendData (0x13), type = Request
10-Jan-2019 10:16:32.809 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0A 00 13 02 03 70 05 7A 25 6E A3
10-Jan-2019 10:16:32.824 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
10-Jan-2019 10:16:32.825 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: TID 409: Transaction not completed
10-Jan-2019 10:16:32.844 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 110, Status = Transmission complete and ACK received(0)
10-Jan-2019 10:16:32.845 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: TID 409: Transaction not completed
10-Jan-2019 10:16:37.846 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 2: TID 409: Timeout at state WAIT_DATA. 3 retries remaining.
10-Jan-2019 10:16:37.846 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
10-Jan-2019 10:16:37.846 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: notifyTransactionResponse TID:409 CANCELLED
10-Jan-2019 10:16:37.848 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 2: Node Init response (8) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@7163e3e0
10-Jan-2019 10:16:37.848 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 2: No data from device, but it was ACK'd. Possibly not supported? (Try 8)
(Kris K) #450
I had to factory reset things a few times and eventually it all came back… what a darn nightmare!
Hopefully with a clean slate things will improve, it would appear the inclusion process was problematic at least a few times before I finally got it right.
(Andy Rigby) #451
Hi @chris, I’ve updated openhab to 2.4 stable and I’ve installed snapshot version of the binding. Here’s the output https://pastebin.com/uyUSH6ze (Node 24) - I see the message:
2019-01-10 12:31:07.463 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 24: Alarm converter NOTIFICATION event is 23, channel alarm_access is not implemented.
Interestingly, I noticed I do see the channel listed in PaperUI:Paper%20UI%202019-01-10%2012-39-19
Snapshot version:
openhab> bundle:list -s|grep zw
263 x Active   x  80 x 2.5.0.201901092308     x org.openhab.binding.zwave
Please let me know if there’s anything else you need.
Thanks,
Andy.
(Mr. Wiseman) #452
Hi Chris!
Can you point me in the right direction if there is one?
I have a zWave network at home working great with your v2.5 build. At work; I’d like to add a few zWave devices and have them send their status over the Internet to my controller at home.
I know natively zWave is NOT IP based but I thought I’d ask the best way to accomplish this? I have control of the firewall on both sides of the equation.
I saw this on the Internet about “maybe” how this could be done but it’s a bit over my head.
Best, Jay
(SiHui) #453
Did you delete the Things and readd them? If not, please do:
(SiHui) #454
If both networks are running openHAB you could connect those via MQTT:
(Markus Storm) #455
Please stick to a thread topic and don’t address developers with generic questions
(while @chris for sure is a very helpful guy, he’s busy and there’s other to answer that well, too).
That being said, you first need another computer with a ZWave stick at work. There’s a variety of options how it can talk to your home server, probably the best is to use a MQTT client (but not another full blown openHAB).
(Andy Rigby) #456
Hi, yes, I’ve deleted them via PaperUI, then added them again from the Inbox. All my other sensors seem t work fine (after updating a few channel names), it’s just the HS1DS that don’t seem to work the same way as in 2.3.
(David) #457
I realize I should probably have posted this here.
I am having trouble with a zwave sensor not updating items after an alarm_burglar event. This after upgrade to 2.4, it was working before.
It is a bit similar to this post, but in that case it seemed to have been fixed with an updated to the binding, which I assume was included in 2.4 (or?).
(Chris Jackson) #458
Not really - it’s probably best to create a new thread as it’s easier to follow than this, now rather long monolith… Unfortunately I didn’t see the other thread though, but I’ve now updated the definition.
(Ulrich) #459
As I learned from an other thread how to update only this binding, I tried it with version 2.5.0.201901061034. But the error still occurs.
2019-01-11 20:31:13.397 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred during notification about bridge status change on thing 'zwave:device:gehirn:node13': 1
java.lang.ArrayIndexOutOfBoundsException: 1
	at org.openhab.binding.zwave.handler.ZWaveThingHandler.initialiseNode(ZWaveThingHandler.java:222) ~[?:?]
(Chris Jackson) #460
Have you deleted the thing and added it back again? If not, it will still be using the old database definition as OH will not update otherwise.
(Ulrich) #461
I’haven’t been aware of it. Now it works!
Thanks a lot Chris!
