I have waked up one of the devices and that worked. The other one showed that it woke up but the backend did not show any signs of recognition. I removed the node and reinserted.
Now it all works like a charm!
So has anyone managed to get this running on 2.3? 2.4 breaks another binding of mine and my older Z-wave development w/ security binding lacks a new Z-wave device in the DB. I.e canât really upgrade to 2.4 right now and it would be great if it was possible to get this running on 2.3 so I can install my new device.
Yes - it should work ok under 2.3, but you obviously need to install manually if youâre on the stable branch.
Installation: openhabian on Raspberry 3B
Update: openHAB 2.4.0 Build # 1380
Aeotec Gen5 USB stick
Things about PaperUI installed.
Update process as above.
If I remove those things, then delete the zwave binding, cache and temp empty, reboot OH and then reinstall the zwave binding,
things are automatically transferred to the inbox.
Is that correct?
My problem is that all power devices are working properly and all battery devices are not working. e.g .:
With the Fibaro Motion Sensor FMGS001 zw2.7, the motion detector only works with the channel alarm_tamper!
You need to wake the battery devices up -:
I woke up at least 100 times
Then please check the debug logs to be sure that the device is waking up - this is the only thing that should stop battery devices initialising.
Where do I see this?
2018-10-04 13:20:56.280 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 49 84 19 0D 04 A1 02 30 9C 60 85 8E 72 70 86 80 84 D5
2018-10-04 13:20:56.289 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationUpdate[73], type=Request[0], dest=25, callback=132, payload=84 19 0D 04 A1 02 30 9C 60 85 8E 72 70 86 80 84
2018-10-04 13:20:56.294 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationUpdate[73], type=Request[0], dest=25, callback=132, payload=84 19 0D 04 A1 02 30 9C 60 85 8E 72 70 86 80 84
2018-10-04 13:20:56.296 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-04 13:20:56.298 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2018-10-04 13:20:56.300 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2018-10-04 13:20:56.304 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=ApplicationUpdate[73], type=Request[0], dest=25, callback=132, payload=84 19 0D 04 A1 02 30 9C 60 85 8E 72 70 86 80 84
2018-10-04 13:20:56.306 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 25: Application update request. Node information received. Transaction null
2018-10-04 13:20:56.308 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: resetResendCount initComplete=true isDead=false
2018-10-04 13:20:56.310 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 25: Application update - no transaction.
2018-10-04 13:20:56.312 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-04 13:20:56.314 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-04 13:20:56.563 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: Is awake with 0 messages in the queue
2018-10-04 13:20:56.567 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: Start sleep timer at 1000ms
2018-10-04 13:20:56.569 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 25: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2018-10-04 13:20:56.602 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 25: Node Status event - Node is AWAKE
2018-10-04 13:20:56.613 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:512:node25' has been updated.
2018-10-04 13:20:57.069 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: WakeupTimerTask 0 Messages waiting, state DONE
2018-10-04 13:20:57.568 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: WakeupTimerTask 0 Messages waiting, state DONE
2018-10-04 13:20:57.570 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: No more messages, go back to sleep
2018-10-04 13:20:57.572 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 25: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2018-10-04 13:20:57.574 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: SECURITY not supported
2018-10-04 13:20:57.576 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2018-10-04 13:20:57.578 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 25: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1c4594d
2018-10-04 13:20:57.581 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 25: Bump transaction 430 priority from Immediate to Immediate
2018-10-04 13:20:57.584 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 25: Adding to device queue
2018-10-04 13:20:57.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 25: Added 430 to queue - size 7
2018-10-04 13:20:57.589 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-04 13:20:57.593 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 19 02 84 08 25 41 16
2018-10-04 13:20:57.596 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 25: Sending REQUEST Message = 01 09 00 13 19 02 84 08 25 41 16
2018-10-04 13:20:57.598 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2018-10-04 13:20:57.600 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 65
2018-10-04 13:20:57.601 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2018-10-04 13:20:57.604 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-10-04 13:20:57.606 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-10-04 13:20:57.613 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 65
2018-10-04 13:20:57.613 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-10-04 13:20:57.616 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2018-10-04 13:20:57.616 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-10-04 13:20:57.617 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-04 13:20:57.620 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2018-10-04 13:20:57.622 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-10-04 13:20:57.625 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 65
2018-10-04 13:20:57.627 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-10-04 13:20:57.627 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 41 00 00 03 A9
2018-10-04 13:20:57.629 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 430: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 65
2018-10-04 13:20:57.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=65, payload=41 00 00 03
2018-10-04 13:20:57.635 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-10-04 13:20:57.637 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 25: sentData successfully placed on stack.
2018-10-04 13:20:57.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 430: Advanced to WAIT_REQUEST
2018-10-04 13:20:57.641 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 25: TID 430: Transaction not completed
2018-10-04 13:20:57.644 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=65, payload=41 00 00 03
2018-10-04 13:20:57.646 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 430: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 65
2018-10-04 13:20:57.647 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-10-04 13:20:57.649 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 430: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 65
2018-10-04 13:20:57.651 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 430: (Callback 65)
2018-10-04 13:20:57.653 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2018-10-04 13:20:57.655 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 430: callback 65
2018-10-04 13:20:57.657 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=65, payload=41 00 00 03
2018-10-04 13:20:57.659 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 25: SendData Request. CallBack ID = 65, Status = Transmission complete and ACK received(0)
2018-10-04 13:20:57.661 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: resetResendCount initComplete=true isDead=false
2018-10-04 13:20:57.663 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 430: Transaction COMPLETED
2018-10-04 13:20:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 25: Response processed after 65ms
2018-10-04 13:20:57.667 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 25: TID 430: Transaction completed
2018-10-04 13:20:57.669 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 25: notifyTransactionResponse TID:430 DONE
2018-10-04 13:20:57.671 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 25: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-10-04 13:20:57.673 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-04 13:20:57.671 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 430: Transaction event listener: DONE: DONE ->
2018-10-04 13:20:57.675 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-04 13:20:57.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 25: Went to sleep COMPLETE
This shows that initialisation is complete. If itâs not really complete, you will need to get a full log from binding startup, or reinitialisation (through the reinitialise menu option) of the device so we can see what is happening.
Do you mean the complete openhab.log?
But I can not attach the * .log.
You can put it on a file sharing service and include the link in the post. Or, you can open a ticket on Chrisâs web site and attach the log to the ticket.
https://www.cd-jackson.com/index.php/tickets
Thanks, could it attach to a ticket.
sending:
Log of reinitialization Node 26
Fibaro Flood Sensor today at 10:40
Ticket ID :P3T28d9NqGC
Done !
Reinitializing each device solved my problem.
@chris, thanks a lot for the amazing job on the refactoring.
I have a ânewbieâ type of question : The devices I use (Popp valves) are offering a dedicated command âCOMMAND_CLASS_PROTECTIONâ which allows to lock the local configuration of the valve.
I was wondering if there is a way for me to send this command with the binding and where I should look to understand how to do that.
Thanks again,
Iâm glad - I just looked at your log and it looks fine so Iâm pleased itâs working .
No - this isnât currently possible. Please can you raise an issue and Iâll have a look at what is required. This class is fundamentally supported, but needs a bit more code to make it available via a channel.
Ok, I submitted an issue. Thanks a lot for the support!
Since I updated to the latest openHAB version my z-wave nodes donât work anymore. I already deleted all z-wave things and the controller and added them via PaperUI again.
Here is a little excerpt from the log viewer. The shown devices are Fibaro Wall Plugs.
2018-10-12 20:38:52.465 [hingStatusInfoChangedEvent] - 'zwave:device:762b5c8d:node5' changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to ONLINE: Node initialising: GET_CONFIGURATION
2018-10-12 20:38:52.473 [hingStatusInfoChangedEvent] - 'zwave:device:762b5c8d:node5' changed from ONLINE: Node initialising: GET_CONFIGURATION to ONLINE: Node initialising: DYNAMIC_VALUES
2018-10-12 20:39:56.529 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:c_f_wp_01 in ManagedMetadataProviderImpl, because it does not exists.
2018-10-12 20:41:13.185 [hingStatusInfoChangedEvent] - 'zwave:device:762b5c8d:node2' changed from ONLINE: Node initialising: PING to ONLINE
2018-10-12 20:41:28.049 [hingStatusInfoChangedEvent] - 'zwave:device:762b5c8d:node2' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
Neither of them is working.
Is there something else I need to do to get them working again?
The device seems to have occasionally communicated, but if the binding is showing it offline, then it means that there are some responses missing.
Maybe they are too far away from the controller? Or maybe thereâs another issue - itâs really hard to say without the debug log though - what youâve provided is the events log.
