Thanks Andrew -
I updated the system using the openhabian-config tool to the latest SNAPSHOT … I ended up with openHAB 3.4.0 Build #3029. The above link says build 3.3.0 but is that a typo?
Anyway, after updating and restarting, I got a slew of Zigbee errors (see below) … will reboot to see if it repeats. Rebooted … system is slowly coming up … it takes about 30 minutes for the Zigbee devices to all come ONLINE (I have ~50 devices), then the ZWave devices follow … so far so good. Ok, all the zigbee devices came up but the Zwave devices are all in Error:Bridge … same as before I had high hopes! Zwave DEBUG was not on so I dont know if its the same (seems likely)
I’ll take another stab at it tomorrow with DEBUG enabled.
2022-08-02 20:28:38.836 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.zigbee.internal.converter.ZigBeeConverterMeteringSummationDelivered.initializeDevice(ZigBeeConverterMeteringSummationDelivered.java:76) ~[?:?]
at org.openhab.binding.zigbee.discovery.ZigBeeDiscoveryService$2.run(ZigBeeDiscoveryService.java:260) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
2022-08-02 20:28:38.854 [ERROR] [ng.zigbee.handler.ZigBeeThingHandler] - null: Exception creating channels
at java.util.concurrent.ConcurrentHashMap.get(ConcurrentHashMap.java:936) ~[?:?]
at com.zsmartsystems.zigbee.ZigBeeNetworkManager.getNode(ZigBeeNetworkManager.java:1646) ~[bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.getNode(ZigBeeCoordinatorHandler.java:992) ~[bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.createZigBeeChannelConverter(ZigBeeThingHandler.java:525) ~[bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.doNodeInitialisation(ZigBeeThingHandler.java:385) [bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler$1.call(ZigBeeThingHandler.java:227) [bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler$1.call(ZigBeeThingHandler.java:1) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2022-08-02 20:28:38.833 [ERROR] [ng.zigbee.handler.ZigBeeThingHandler] - null: Exception getting binding table
java.util.concurrent.ExecutionException: java.lang.NullPointerException
at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:?]
at java.util.concurrent.FutureTask.get(FutureTask.java:191) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.doNodeInitialisation(ZigBeeThingHandler.java:445) [bundleFile:?]
Caused by: java.lang.NullPointerException
at com.zsmartsystems.zigbee.ZigBeeNode$1.call(ZigBeeNode.java:465) ~[?:?]
at com.zsmartsystems.zigbee.ZigBeeNode$1.call(ZigBeeNode.java:454) ~[?:?]
... 1 more
2022-08-02 20:28:38.818 [ERROR] [ng.zigbee.handler.ZigBeeThingHandler] - null: Exception getting binding table
... 1 more
at org.openhab.binding.zigbee.internal.converter.ZigBeeConverterSwitchOnoff.initializeDevice(ZigBeeConverterSwitchOnoff.java:105) ~[?:?]
2022-08-02 20:28:38.828 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.zigbee.discovery.ZigBeeNodePropertyDiscoverer.addPropertiesFromBasicCluster(ZigBeeNodePropertyDiscoverer.java:157) ~[?:?]
at org.openhab.binding.zigbee.discovery.ZigBeeNodePropertyDiscoverer.getProperties(ZigBeeNodePropertyDiscoverer.java:109) ~[?:?]
at org.openhab.binding.zigbee.discovery.ZigBeeDiscoveryService$2.run(ZigBeeDiscoveryService.java:222) ~[?:?]
at com.zsmartsystems.zigbee.zcl.ZclCluster.readSync(ZclCluster.java:1727) ~[?:?]
at com.zsmartsystems.zigbee.zcl.clusters.ZclBasicCluster.getStackVersion(ZclBasicCluster.java:393) ~[?:?]
at org.openhab.binding.zigbee.discovery.ZigBeeNodePropertyDiscoverer.addPropertiesFromBasicCluster(ZigBeeNodePropertyDiscoverer.java:204) ~[?:?]
2022-08-02 20:28:38.934 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2022-08-02 20:28:38.825 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at com.zsmartsystems.zigbee.zcl.clusters.ZclBasicCluster.getDateCode(ZclBasicCluster.java:673) ~[?:?]
at org.openhab.binding.zigbee.discovery.ZigBeeNodePropertyDiscoverer.addPropertiesFromBasicCluster(ZigBeeNodePropertyDiscoverer.java:222) ~[?:?]
2022-08-02 20:28:38.900 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at com.zsmartsystems.zigbee.ZigBeeNetworkManager.getNode(ZigBeeNetworkManager.java:1646) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.getNode(ZigBeeCoordinatorHandler.java:992) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.doNodeInitialisation(ZigBeeThingHandler.java:238) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler$1.call(ZigBeeThingHandler.java:227) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler$1.call(ZigBeeThingHandler.java:1) ~[?:?]
2022-08-02 20:28:38.909 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2022-08-02 20:28:38.794 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.getNodeEndpoints(ZigBeeCoordinatorHandler.java:885) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.doNodeInitialisation(ZigBeeThingHandler.java:266) ~[?:?]
2022-08-02 20:28:38.949 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2022-08-02 20:28:38.951 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2022-08-02 20:28:38.958 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
Done.
