Hi all,
as it has happened now for the the second time and I don’t know why I’d like to ask if this is a known issue or how I can prevent that. I’ running the following setup:
- openHAB 2.5.11 Release Build
- Raspberry 4
- Openhabian OS
- Sigma Designs Controller Z-Wave Plus USB-Dongle
Both times it started with the situation that I couldn’t access the configuration of my Z-Wave devices anymore, the menu topic just didn’t appear, neither in Habmin, nor in Paper UI. After some research if found that I had suddenly two Z-Wave bundles installed (not initiated by me):
openhab> bundle:list | grep Add-on
229 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Airquality Binding
230 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Amazon Echo Control Binding
231 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: CoronaStats Binding
232 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Denon / Marantz Binding
233 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: DwdUnwetter Binding
234 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: EnOcean Binding
235 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Exec Binding
236 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Feed Binding
239 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Log Reader Binding
240 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Network Binding
241 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: OpenWeatherMap Binding
244 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: SqueezeBox Binding
246 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: ZigBee Binding
247 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: ZigBee CC2531 Bridge
248 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: ZigBee Console
249 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: ZigBee Console Ember
250 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: ZigBee Ember Bridge
251 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: ZigBee Telegesis Bridge
252 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: ZigBee XBee Bridge
263 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Extension Service :: Eclipse IoT Marketplace
265 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: IO :: Java Sound Support
266 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: IO :: openHAB Cloud Connector
267 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: IO :: Web Audio Support
270 │ Active │ 75 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Transformation Service :: JavaScript
271 │ Active │ 75 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Transformation Service :: JSonPath
272 │ Active │ 75 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Transformation Service :: Map
273 │ Active │ 75 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Transformation Service :: RegEx
274 │ Active │ 75 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Transformation Service :: Scale
275 │ Active │ 75 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Transformation Service :: XPath
276 │ Active │ 75 │ 2.5.11 │ openHAB Add-ons :: Bundles :: Transformation Service :: Xslt
282 │ Active │ 80 │ 1.0.0 │ openHAB Add-ons :: Bundles :: FlicButton Binding
285 │ Active │ 80 │ 2.5.12.202012180333 │ openHAB Add-ons :: Bundles :: ZWave Binding
288 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: MagentaTV Binding
289 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: ZWave Binding
So what I did was stoping and uninstalling the older version.
openhab> bundle:stop 289
openhab> bundle:uninstall 289
I have installed the newer version recently because of some other issues. This was done manually.
After getting rid of the older bundle everything was fine again, Z-Wave device configuration was back again and accessible.
I know now how to notice the problem and how to fix it, if it happens again. Nevertheless it a bit odd and may point to a much bigger problem that will bite me later.
Have you seen such issue before or can point me to the root cause of it?
Best,
Jens
