plysdyret
(Torkil Svensgaard)
January 9, 2020, 10:03am
#1
Hi
Device (a power plug) is not sending events as expected. It was removed and re-added 24 hours ago and just now again.
Trying to heal it wields the following:
Can not start heal as initialisation is not complete (SUC_ROUTE)
Stuck somehow, given I waited 24 hours? Any suggestions on how to get it going?
openhab> bundle:list | grep ZWave
382 │ Active │ 80 │ 2.5.1.202001070048 │ openHAB Add-ons :: Bundles :: ZWave Binding
Mvh.
Torkil
H102
(CM6.5 H102)
January 9, 2020, 2:15pm
#2
Did you add the ZWave binding from PaperUI or jar file?
Try deleting (do NOT exclude from the network) & re-discovering the Thing. The binding apparently has not completed discovery.
I have had to do this occasionally. The new Thing will have the same ID so all Items and Rules will work OK.
plysdyret
(Torkil Svensgaard)
January 9, 2020, 2:32pm
#4
plysdyret
(Torkil Svensgaard)
January 9, 2020, 2:34pm
#5
Bruce_Osborne:
Thanks, but I did that a number of times already.
Mvh.
Torkil
sihui
(SiHui)
January 10, 2020, 6:34am
#6
As you are using a recent zwave binding and already readded the Thing you may need to exclude and reinclude.
BTW, I have two of those devices and this cheap stuff is crap, buy a better product.
plysdyret
(Torkil Svensgaard)
January 10, 2020, 6:56am
#7
Thanks, I’ll try that.
Is there a particular product you can recommend instead?
Mvh.
Torkil
sihui
(SiHui)
January 10, 2020, 6:57am
#8
plysdyret
(Torkil Svensgaard)
January 10, 2020, 1:31pm
#9
plysdyret:
Oh joy, not possible since I have a things file
Hi everybody,
maybe its a silly question, but…
i defined my Z-Wave controller inside a things file (a Razberry). I understand that I can’t edit the name using PaperUI… but I want to enable the exclude mode. But this isn’t possible either… I just geht an 409 error because my controller thing is defined in a textfile and configuration can’t be modified. Do I really need to alter the file to put the controller in exclude mode???
Factory reset here I come.
Mvh.
Torkil
Try renaming the file or Thing and delete in the UI if necessary,
Rename back and it should be good
plysdyret
(Torkil Svensgaard)
January 10, 2020, 1:47pm
#11
Of course, thanks. I swapped it for another device for now, hopefully some time off will make it behave when I need it next.
Mvh.
Torkil
plysdyret
(Torkil Svensgaard)
January 13, 2020, 9:28am
#12
I had to reboot the VM and now the new device is experiencing the same symptoms.
Is it possible there some kind of interference from having devices too close together? I have 3 in a wall socket similar to this one:
Mvh.
Torkil
