I know, probably not the best idea but never mind! It’s been configured and waiting to go for about a year, I keep coming back to it to try to sort it. Got so annoyed with not being able to adjust the brightness of my lights from the oh1.8 web interface on my iPhone that I decided to take the plunge and swap over.
I’ve just managed to get it working properly with the zwave1 binding, I now realise that wasn’t working due to the serial port not being in EXTRA_JAVA_OPT.
addons.cfg:
package =expert
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required for the installation of
# any legacy 1.x add-on. (default is true)
remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation of 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (default is false)
legacy = true
# A comma-separated list of bindings to install (e.g. "binding = sonos,knx,zwave")
binding = mqtt1,squeezebox,zwave,astro1,serial1
# A comma-separated list of UIs to install (e.g. "ui = basic,paper")
ui = basic,classic,paper
# A comma-separated list of persistence services to install (e.g. "persistence = rrd4j,jpa")
persistence = mapdb,mysql
# A comma-separated list of actions to install (e.g. "action = mail,pushover")
action = prowl
# A comma-separated list of transformation services to install (e.g. "transformation = map,jsonpath")
transformation = xslt,map
# A comma-separated list of voice services to install (e.g. "voice = marytts,freetts")
#voice =
# A comma-separated list of miscellaneous services to install (e.g. "misc = myopenhab")
#misc =
.config:
:org.apache.felix.configadmin.revision:=L"35"
action="prowl"
binding="mqtt1,squeezebox,zwave,astro1,weather1,serial1"
legacy="true"
package="expert"
persistence="mapdb,mysql"
remote="true"
service.pid="org.openhab.addons"
transformation="xslt,map"
ui="basic,classic,paper,habmin"
