Hi thefathefa
have you been able to fix issue?
I have same issue than you:
2019-10-10 23:34:26.679 [thome.event.ExtensionEvent] - Extension 'binding-zwave' has been installed.
2019-10-10 23:36:19.496 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_87d5069e_serial_sof-zwave:serial_zstick:87d5069e:serial_sof' has been added.
2019-10-10 23:36:19.511 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_87d5069e_serial_ack-zwave:serial_zstick:87d5069e:serial_ack' has been added.
2019-10-10 23:36:19.514 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_87d5069e_serial_nak-zwave:serial_zstick:87d5069e:serial_nak' has been added.
2019-10-10 23:36:19.517 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_87d5069e_serial_can-zwave:serial_zstick:87d5069e:serial_can' has been added.
2019-10-10 23:36:19.520 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_87d5069e_serial_oof-zwave:serial_zstick:87d5069e:serial_oof' has been added.
2019-10-10 23:36:19.523 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_87d5069e_serial_cse-zwave:serial_zstick:87d5069e:serial_cse' has been added.
2019-10-10 23:36:19.573 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:87d5069e' changed from UNINITIALIZED to INITIALIZING
2019-10-10 23:36:19.602 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:87d5069e' has been updated.
2019-10-10 23:36:19.607 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyAMA0'
2019-10-10 23:36:19.609 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:87d5069e' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-10-10 23:36:19.628 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-10-10 23:36:19.645 [vent.ItemStateChangedEvent] - zwave_serial_zstick_87d5069e_serial_sof changed from NULL to 0
2019-10-10 23:36:19.647 [vent.ItemStateChangedEvent] - zwave_serial_zstick_87d5069e_serial_ack changed from NULL to 0
2019-10-10 23:36:19.653 [vent.ItemStateChangedEvent] - zwave_serial_zstick_87d5069e_serial_nak changed from NULL to 0
2019-10-10 23:36:19.657 [vent.ItemStateChangedEvent] - zwave_serial_zstick_87d5069e_serial_can changed from NULL to 0
2019-10-10 23:36:19.665 [vent.ItemStateChangedEvent] - zwave_serial_zstick_87d5069e_serial_oof changed from NULL to 0
2019-10-10 23:36:19.668 [vent.ItemStateChangedEvent] - zwave_serial_zstick_87d5069e_serial_cse changed from NULL to 0
2019-10-10 23:36:19.672 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-10-10 23:36:19.674 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
but in my case I’m using a new Raspberry Pi 4 Model B Rev 1.1:
############### openhab #####################################################
## Ip = 192.168.1.143
## Release = Raspbian GNU/Linux 10 (buster)
## Kernel = Linux 4.19.57-v7l+
## Platform = Raspberry Pi 4 Model B Rev 1.1
## Uptime = 0 day(s). 0:25:59
## CPU Usage = 0% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.00, 5m: 0.00, 15m: 0.00
## Memory = Free: 3.23GB (84%), Used: 0.63GB (16%), Total: 3.86GB
## Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
## Root = Free: 53.54GB (95%), Used: 2.36GB (5%), Total: 58.30GB
## Updates = 0 apt updates available.
## Sessions = 2 session(s)
## Processes = 119 running processes of 32768 maximum processes
I have also checked serial port and tty:
[23:55:21] openhabian@openhab:~$ cat /etc/default/openhab2 | grep SerialPorts
## EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0"
## EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0"
## EXTRA_JAVA_OPTS="-Djna.library.path=/lib/arm-linux-gnueabihf/ -Duser.timezone=Europe/Berlin -Dgnu.io.rxtx.SerialPorts=/dev/ttyS0"
EXTRA_JAVA_OPTS="-Xms250m -Xmx350m -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0"
[23:58:08] openhabian@openhab:~$ dmesg -T | grep tty
[Thu Oct 10 23:29:19 2019] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M smsc95xx.macaddr=DC:A6:32:29:88:73 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=be1d5779-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[Thu Oct 10 23:29:19 2019] console [tty1] enabled
[Thu Oct 10 23:29:19 2019] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[23:59:33] openhabian@openhab:~$ ls -lah /dev/ttyA*
crw-rw---- 1 root dialout 204, 64 Oct 10 23:29 /dev/ttyAMA0
I have also ran the following checks on the USB / serial interfaces:
[23:58:47] openhabian@openhab:~$ dmesg | grep -i usb
[ 0.073137] usbcore: registered new interface driver usbfs
[ 0.073203] usbcore: registered new interface driver hub
[ 0.073312] usbcore: registered new device driver usb
[ 0.392993] usbcore: registered new interface driver r8152
[ 0.393070] usbcore: registered new interface driver lan78xx
[ 0.393137] usbcore: registered new interface driver smsc95xx
[ 0.393398] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.396307] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.396340] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.396369] usb usb1: Product: xHCI Host Controller
[ 0.396392] usb usb1: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[ 0.396416] usb usb1: SerialNumber: 0000:01:00.0
[ 0.396939] hub 1-0:1.0: USB hub found
[ 0.397457] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.397495] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.397844] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.397876] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.397905] usb usb2: Product: xHCI Host Controller
[ 0.397928] usb usb2: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[ 0.397952] usb usb2: SerialNumber: 0000:01:00.0
[ 0.398444] hub 2-0:1.0: USB hub found
[ 0.425187] dwc_otg fe980000.usb: base=(ptrval)
[ 0.826959] dwc_otg fe980000.usb: DWC OTG Controller
[ 0.827002] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ 0.827054] dwc_otg fe980000.usb: irq 37, io mem 0x00000000
[ 0.827411] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.827443] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.827472] usb usb3: Product: DWC OTG Controller
[ 0.827495] usb usb3: Manufacturer: Linux 4.19.75-v7l+ dwc_otg_hcd
[ 0.827519] usb usb3: SerialNumber: fe980000.usb
[ 0.828048] hub 3-0:1.0: USB hub found
[ 0.828933] usbcore: registered new interface driver uas
[ 0.829064] usbcore: registered new interface driver usb-storage
[ 0.835368] usbcore: registered new interface driver usbhid
[ 0.835391] usbhid: USB HID core driver
[ 0.971642] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.153278] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 1.153319] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.153347] usb 1-1: Product: USB2.0 Hub
[ 1.154917] hub 1-1:1.0: USB hub found
[ 3.948873] usbcore: registered new interface driver brcmfmac
Were you able to fix issue?
If so, would you mind helping me with this issue
Thanks in advance
