I’m trying to move over finally from OH1 to OH2. So I just moved all my zwave devices off of my old Aeon Zstick to a new Aeon Gen5 Stick. I excluded all devices and then re-added to the new stick, except I added them using OpenZWave as I already had that configured.
But when I start OH2, and configure 2.0 Zwave binding Port to look for the new stick at /dev/ttyACM0, I get a Controller is offline message. Yet the log seems to not indicate anything wrong and shows the device found and initialized?
I can also stop OH2 and reconnect to the stick with ozcwp and see all the devices, so I know the port number is correct.
This is from the log
2016-10-29 21:39:40.788 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2016-10-29 21:39:41.432 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2016-10-29 21:39:41.588 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
2016-10-29 21:39:41.837 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2016-10-29 21:39:41.885 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2016-10-29 21:39:42.179 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2016-10-29 21:39:47.145 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2016-10-29 21:39:47.524 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2016-10-29 21:39:47.531 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2016-10-29 21:39:47.600 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2016-10-29 21:39:47.601 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2016-10-29 21:39:55.878 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-10-29 21:40:01.071 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-10-29 21:40:01.885 [WARN ] [WaveSerialHandler$ZWaveReceiveThread] - Protocol error (OOF). Got 0x13.
2016-10-29 21:40:02.387 [WARN ] [WaveSerialHandler$ZWaveReceiveThread] - Protocol error (OOF). Got 0x07.
2016-10-29 21:40:04.010 [WARN ] [WaveSerialHandler$ZWaveReceiveThread] - Protocol error (OOF). Got 0x20.
2016-10-29 21:40:06.074 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
Anyone have any thoughts on where to go looking to troubleshoot?
