I had used zwave-js-ui to update the firmware of some of my Jasco dimmers. After doing so, I turned off zwave-js-ui and restarted openhab. Since then my ZWave Controller has remained offline. The only thing I see in the logs are:
2022-12-26 18:55:33.629 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - No bridgeUID found in getConfigDescription thing:zwave:serial_zstick:737356779e
2022-12-26 18:55:33.675 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Disposing receive thread
2022-12-26 18:55:33.676 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Receive thread dispose
2022-12-26 18:55:33.676 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Disposing serial connection
2022-12-26 18:55:33.677 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Serial connection disposed
2022-12-26 18:55:33.678 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2022-12-26 18:55:33.679 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
2022-12-26 18:55:33.679 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller zwave:serial_zstick:737356779e.
2022-12-26 18:55:33.789 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - No bridgeUID found in getConfigDescription thing:zwave:serial_zstick:737356779e
The controller shows up properly in zwave-js-ui and I’m able to control the nodes from there but in openhab the controller just remains offline. I’m using Aotec Z-stick gen5 in case that helps. Any ideas?
EDIT: It seems to work now. Not sure what exactly the issue was. Things I did:
- Upgraded zwave stick firmware from 1.0 to 1.2.
- Set the S0 and S2 security keys using zwave-js-ui.
- Completely restarted host device again (not just openhab docker container, which had no effect after restarting multiple times).
