Hi All
Having issues with a Aeotec ZW132 latest firmware.
It doesnt report the manual switch state, but works just fine otherwise.
When I use the manual switch, I see a corrupted payload message in the binding. I am using Hail CC for the Parameter 80 but ive tried the other settings also and still no switch state
Im using the latest development binding 2.5
Any thoughts as to why?
@ihp:/etc/openhab2$ tail -f /var/log/openhab2/zwave.log | grep "NODE 30"
25-Jul-2019 07:09:54.295 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Message payload = 00 1E 06 60 0D 02 01 82 01
25-Jul-2019 07:09:54.295 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
25-Jul-2019 07:09:54.296 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
25-Jul-2019 07:09:54.296 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
25-Jul-2019 07:09:54.296 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: COMMAND_CLASS_MULTI_CHANNEL corrupted payload 60 0D 02 01 82 01
25-Jul-2019 07:10:03.344 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Message payload = 00 1E 06 60 0D 02 01 82 01
25-Jul-2019 07:10:03.345 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
25-Jul-2019 07:10:03.345 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
25-Jul-2019 07:10:03.345 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
25-Jul-2019 07:10:03.345 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: COMMAND_CLASS_MULTI_CHANNEL corrupted payload 60 0D 02 01 82 01
When I set it to Basic CC
I see this:
kris@ihp:/etc/openhab2$ tail -f /var/log/openhab2/zwave.log | grep "NODE 30"
25-Jul-2019 07:13:41.294 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Message payload = 00 1E 07 60 0D 02 01 20 03 FF
25-Jul-2019 07:13:41.294 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
25-Jul-2019 07:13:41.294 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
25-Jul-2019 07:13:41.294 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
25-Jul-2019 07:13:41.294 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Incoming command class COMMAND_CLASS_BASIC, endpoint 2
25-Jul-2019 07:13:41.294 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
25-Jul-2019 07:13:41.294 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 30: Received COMMAND_CLASS_BASIC V0 BASIC_REPORT
25-Jul-2019 07:13:41.294 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 30: Basic report, value = 255
25-Jul-2019 07:13:41.294 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
25-Jul-2019 07:13:41.294 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got a value event from Z-Wave network, endpoint=2, command class=COMMAND_CLASS_BASIC, value=255
25-Jul-2019 07:13:41.294 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:scene_number, cmdClass=COMMAND_CLASS_SCENE_ACTIVATION, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage, cmdClass=COMMAND_CLASS_METER, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts, cmdClass=COMMAND_CLASS_METER, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh, cmdClass=COMMAND_CLASS_METER, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current, cmdClass=COMMAND_CLASS_METER, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_reset, cmdClass=COMMAND_CLASS_METER, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_power, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_heat, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:time_offset, cmdClass=COMMAND_CLASS_CLOCK, endpoint=0
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary1, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=1
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage1, cmdClass=COMMAND_CLASS_METER, endpoint=1
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts1, cmdClass=COMMAND_CLASS_METER, endpoint=1
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh1, cmdClass=COMMAND_CLASS_METER, endpoint=1
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current1, cmdClass=COMMAND_CLASS_METER, endpoint=1
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary2, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=2
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage2, cmdClass=COMMAND_CLASS_METER, endpoint=2
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts2, cmdClass=COMMAND_CLASS_METER, endpoint=2
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh2, cmdClass=COMMAND_CLASS_METER, endpoint=2
25-Jul-2019 07:13:41.295 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current2, cmdClass=COMMAND_CLASS_METER, endpoint=2
25-Jul-2019 07:13:41.295 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Commands processed 1.
25-Jul-2019 07:13:41.295 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@64a70cca.
But still no state report
Regards
