Well, then that’s why nothing has changed as that was the fix I made as I described earlier. You told me you were using the Hail CC -:
So I fixed this -:
If in fact you’re not using HAIL, you will have to wait for the database to be updated.
So I fixed this -:
Sorry for the confusion, i tried hail, it failed. So I went back to Basic CC, it also failed.
So am I right in saying neither work due to a bug/update required?
I’ve currently only made the one change as above.
Right, so is another required to fix the basic cc? I’m confused.
Clearly, yes.
There were two issues. You told me that you were using the HAIL command class, so I spent time to try and fix this for you.
Now you’ve decided not to use that but to use the BASIC command class which has not been updated yet.
Right. To me, and most people no doubt it makes no difference what command class they use - most users just see it not working. I just use default, which is basic, but at the request of Aeotec to try hail.
It wasn’t clear to me that both had an issue, it now is. Thanks for putting it in the pipeline
You made a clear point of telling me that this is what you were doing, so I worked on the problem that you asked me to look at - my mistake.
Just trying to give as much info as possible all good Chris! sorry for bumsteering you
Hi Chris, where can I find out if the changes have been made to the binding? I couldnt find any info on github, cheers
I’m not sure where you are looking, but the list of PRs is the best place to look.
Shall i create one for this issue?
Create what? A PR?
Yes, because I cant see one for this issue.
Well, if you want to create a PR, then it’s always appreciated, but I didn’t think you were doing programming?
In any case, I believe that this should already be completed?
LOL!
No, i’m not. Im just trying to work out if the issue discussed in this thread is fixed or not because A) I cant see a PR for it, B) I cant find any release notes or info was to what is fixed in the various binding updates
You’re funny Chris There’s a question mark. I’m asking you but you’re asking me HAHAH!
Did you look at the recent closed PRs?
I don’t produce release notes for all the database changes - sorry. Release notes are only produced when there is a release - not for snapshots. You need to check the PRs.
Sorry- I’m just a bit confused by your question. As I said, I’m happy if you want to fix issues though.
Thanks Chris, ill look through closed PR’s
I’d love to write something but i’m afraid I wouldn’t be any use to you
I think this PR is the one you are looking for -:
Thank you!
Hi Chris, i updated the binding to the latest but the issue persists, no update of the status when using the manual switch
05-Aug-2019 17:01:00.125 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction : commd >> 3 == 3.
05-Aug-2019 17:01:00.125 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@271e29f8.
05-Aug-2019 17:01:00.126 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:544 DONE
05-Aug-2019 17:01:00.126 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
05-Aug-2019 17:01:00.127 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: listening == true, frequentlyListening == false, awake == false
05-Aug-2019 17:01:00.127 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Creating empty message of class = SendData (0x13), type = Request
05-Aug-2019 17:01:00.128 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 0A 00 13 1E 03 8E 04 03 25 D7 80
05-Aug-2019 17:01:00.143 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
05-Aug-2019 17:01:00.143 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 545: Transaction not completed
05-Aug-2019 17:01:00.232 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 215, Status = Transmission complete and ACK received(0)
05-Aug-2019 17:01:00.232 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
05-Aug-2019 17:01:00.232 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Response processed after 104ms
05-Aug-2019 17:01:00.233 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 545: Transaction completed
05-Aug-2019 17:01:00.233 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:545 DONE
05-Aug-2019 17:01:00.233 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
05-Aug-2019 17:01:00.234 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: listening == true, frequentlyListening == false, awake == false
05-Aug-2019 17:01:00.234 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Creating empty message of class = SendData (0x13), type = Request
05-Aug-2019 17:01:00.234 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 0A 00 13 1E 03 8E 02 03 25 D8 89
05-Aug-2019 17:01:00.238 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Members after controller update ZWaveAssociationGroup [index=2, name=null, profile1=null, profile2=null, associations=[]]
05-Aug-2019 17:01:00.238 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Association group 2 contains no members. Clearing.
05-Aug-2019 17:01:00.238 [DEBUG] [col.commandclass.ZWaveMultiAssociationCommandClass] - NODE 30: Creating new message for command MULTI_ASSOCIATIONCMD_REMOVE node all, endpoint all, group 2
05-Aug-2019 17:01:00.238 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Encapsulating message, endpoint 0
05-Aug-2019 17:01:00.238 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
05-Aug-2019 17:01:00.239 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Command Class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION is NOT required to be secured
05-Aug-2019 17:01:00.239 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Adding to device queue
05-Aug-2019 17:01:00.239 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Added 547 to queue - size 7
05-Aug-2019 17:01:00.239 [DEBUG] [col.commandclass.ZWaveMultiAssociationCommandClass] - NODE 30: Creating new message for command MULTI_ASSOCIATIONCMD_GET group 2
05-Aug-2019 17:01:00.239 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Encapsulating message, endpoint 0
05-Aug-2019 17:01:00.239 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
05-Aug-2019 17:01:00.240 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Command Class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION is NOT required to be secured
05-Aug-2019 17:01:00.240 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Adding to device queue
05-Aug-2019 17:01:00.240 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Added 548 to queue - size 8
05-Aug-2019 17:01:00.240 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored switchall_mode to 255 (BigDecimal)
05-Aug-2019 17:01:00.240 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored action_reinit to false (Boolean)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_112_4 to 600 (BigDecimal)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_113_4 to 600 (BigDecimal)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_111_4 to 10 (BigDecimal)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_20_1 to 0 (BigDecimal)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_84_4 to 301991936 (BigDecimal)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_83_1 to 0 (BigDecimal)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_82_1 to 0 (BigDecimal)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_252_1 to 0 (BigDecimal)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_81_1 to 0 (BigDecimal)
05-Aug-2019 17:01:00.241 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_80_1 to 2 (BigDecimal)
05-Aug-2019 17:01:00.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_255_4 to 0 (BigDecimal)
05-Aug-2019 17:01:00.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored action_failed to false (Boolean)
05-Aug-2019 17:01:00.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_110_1_wo to 0 (BigDecimal)
05-Aug-2019 17:01:00.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored action_remove to false (Boolean)
05-Aug-2019 17:01:00.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored binding_pollperiod to 86400 (BigDecimal)
05-Aug-2019 17:01:00.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored action_heal to false (Boolean)
05-Aug-2019 17:01:00.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_122_1 to 3 (BigDecimal)
05-Aug-2019 17:01:00.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_123_1 to 3 (BigDecimal)
05-Aug-2019 17:01:00.242 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_144_1 to 0 (BigDecimal)
05-Aug-2019 17:01:00.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_120_1 to 1 (BigDecimal)
05-Aug-2019 17:01:00.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_121_1 to 1 (BigDecimal)
05-Aug-2019 17:01:00.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_101_4 to 0 (BigDecimal)
05-Aug-2019 17:01:00.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_102_4 to 0 (BigDecimal)
05-Aug-2019 17:01:00.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_3_1 to 1 (BigDecimal)
05-Aug-2019 17:01:00.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_4_1 to 0 (BigDecimal)
05-Aug-2019 17:01:00.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored config_103_4 to 0 (BigDecimal)
05-Aug-2019 17:01:00.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Configuration update ignored node_id to 30 (BigDecimal)
05-Aug-2019 17:01:00.245 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
05-Aug-2019 17:01:00.245 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 546: Transaction not completed
05-Aug-2019 17:01:00.303 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 216, Status = Transmission complete and ACK received(0)
05-Aug-2019 17:01:00.303 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
05-Aug-2019 17:01:00.303 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 546: Transaction not completed
05-Aug-2019 17:01:00.382 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Message payload = 00 1E 05 8E 03 03 05 00
05-Aug-2019 17:01:00.382 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
05-Aug-2019 17:01:00.382 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
05-Aug-2019 17:01:00.382 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Incoming command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0
05-Aug-2019 17:01:00.382 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
05-Aug-2019 17:01:00.382 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 30: Received COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION V3 MULTI_ASSOCIATIONCMD_REPORT
05-Aug-2019 17:01:00.382 [DEBUG] [col.commandclass.ZWaveMultiAssociationCommandClass] - NODE 30: association group 3 has max associations 5
05-Aug-2019 17:01:00.382 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveAssociationEvent
05-Aug-2019 17:01:00.382 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ASSOCIATION, value=0
05-Aug-2019 17:01:00.382 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=0
05-Aug-2019 17:01:00.382 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:scene_number, cmdClass=COMMAND_CLASS_SCENE_ACTIVATION, endpoint=0
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_reset, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_power, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_heat, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:time_offset, cmdClass=COMMAND_CLASS_CLOCK, endpoint=0
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary1, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=1
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary2, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=2
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:00.383 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:00.383 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Commands processed 1.
05-Aug-2019 17:01:00.383 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@12e8fb6b.
05-Aug-2019 17:01:00.383 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction 546 ApplicationCommandHandler.
05-Aug-2019 17:01:00.383 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction : state >> WAIT_DATA
05-Aug-2019 17:01:00.383 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction : node >> 30
05-Aug-2019 17:01:00.383 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction : class >> 142 == 142.
05-Aug-2019 17:01:00.383 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction : commd >> 3 == 3.
05-Aug-2019 17:01:00.383 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@12e8fb6b.
05-Aug-2019 17:01:00.383 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:546 DONE
05-Aug-2019 17:01:00.384 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
05-Aug-2019 17:01:00.384 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: listening == true, frequentlyListening == false, awake == false
05-Aug-2019 17:01:00.384 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Creating empty message of class = SendData (0x13), type = Request
05-Aug-2019 17:01:00.384 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 0A 00 13 1E 03 8E 04 02 25 D9 8F
05-Aug-2019 17:01:00.397 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
05-Aug-2019 17:01:00.397 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 547: Transaction not completed
05-Aug-2019 17:01:00.492 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 217, Status = Transmission complete and ACK received(0)
05-Aug-2019 17:01:00.492 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
05-Aug-2019 17:01:00.492 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Response processed after 97ms
05-Aug-2019 17:01:00.492 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 547: Transaction completed
05-Aug-2019 17:01:00.492 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:547 DONE
05-Aug-2019 17:01:00.492 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
05-Aug-2019 17:01:00.493 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: listening == true, frequentlyListening == false, awake == false
05-Aug-2019 17:01:00.493 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Creating empty message of class = SendData (0x13), type = Request
05-Aug-2019 17:01:00.493 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 30: Sending REQUEST Message = 01 0A 00 13 1E 03 8E 02 02 25 DA 8A
05-Aug-2019 17:01:00.506 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 30: sentData successfully placed on stack.
05-Aug-2019 17:01:00.507 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 548: Transaction not completed
05-Aug-2019 17:01:00.572 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 30: SendData Request. CallBack ID = 218, Status = Transmission complete and ACK received(0)
05-Aug-2019 17:01:00.573 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
05-Aug-2019 17:01:00.573 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: TID 548: Transaction not completed
05-Aug-2019 17:01:00.642 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Message payload = 00 1E 05 8E 03 02 05 00
05-Aug-2019 17:01:00.642 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
05-Aug-2019 17:01:00.642 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
05-Aug-2019 17:01:00.642 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Incoming command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0
05-Aug-2019 17:01:00.642 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
05-Aug-2019 17:01:00.642 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 30: Received COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION V3 MULTI_ASSOCIATIONCMD_REPORT
05-Aug-2019 17:01:00.642 [DEBUG] [col.commandclass.ZWaveMultiAssociationCommandClass] - NODE 30: association group 2 has max associations 5
05-Aug-2019 17:01:00.642 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveAssociationEvent
05-Aug-2019 17:01:00.643 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ASSOCIATION, value=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:scene_number, cmdClass=COMMAND_CLASS_SCENE_ACTIVATION, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_reset, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_power, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_heat, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:time_offset, cmdClass=COMMAND_CLASS_CLOCK, endpoint=0
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary1, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=1
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary2, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=2
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:00.643 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:00.644 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Commands processed 1.
05-Aug-2019 17:01:00.644 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@650404f8.
05-Aug-2019 17:01:00.644 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction 548 ApplicationCommandHandler.
05-Aug-2019 17:01:00.644 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction : state >> WAIT_DATA
05-Aug-2019 17:01:00.644 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction : node >> 30
05-Aug-2019 17:01:00.644 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction : class >> 142 == 142.
05-Aug-2019 17:01:00.644 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking transaction : commd >> 3 == 3.
05-Aug-2019 17:01:00.644 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@650404f8.
05-Aug-2019 17:01:00.644 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: notifyTransactionResponse TID:548 DONE
05-Aug-2019 17:01:00.644 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
05-Aug-2019 17:01:48.982 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Message payload = 00 1E 07 60 0D 02 01 20 03 00
05-Aug-2019 17:01:48.983 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
05-Aug-2019 17:01:48.983 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
05-Aug-2019 17:01:48.983 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
05-Aug-2019 17:01:48.983 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Incoming command class COMMAND_CLASS_BASIC, endpoint 2
05-Aug-2019 17:01:48.983 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
05-Aug-2019 17:01:48.983 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 30: Received COMMAND_CLASS_BASIC V0 BASIC_REPORT
05-Aug-2019 17:01:48.984 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 30: Basic report, value = 0
05-Aug-2019 17:01:48.984 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
05-Aug-2019 17:01:48.984 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got a value event from Z-Wave network, endpoint=2, command class=COMMAND_CLASS_BASIC, value=0
05-Aug-2019 17:01:48.984 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=0
05-Aug-2019 17:01:48.984 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:scene_number, cmdClass=COMMAND_CLASS_SCENE_ACTIVATION, endpoint=0
05-Aug-2019 17:01:48.984 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:48.984 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:48.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:48.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:48.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_reset, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:48.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_power, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
05-Aug-2019 17:01:48.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_heat, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
05-Aug-2019 17:01:48.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:time_offset, cmdClass=COMMAND_CLASS_CLOCK, endpoint=0
05-Aug-2019 17:01:48.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary1, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=1
05-Aug-2019 17:01:48.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:48.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:48.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:48.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:48.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary2, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=2
05-Aug-2019 17:01:48.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:48.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:48.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:48.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:48.986 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Commands processed 1.
05-Aug-2019 17:01:48.986 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5963d13d.
05-Aug-2019 17:01:51.982 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 30: Message payload = 00 1E 07 60 0D 02 01 20 03 FF
05-Aug-2019 17:01:51.983 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Application Command Request (ALIVE:DONE)
05-Aug-2019 17:01:51.983 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: resetResendCount initComplete=true isDead=false
05-Aug-2019 17:01:51.983 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
05-Aug-2019 17:01:51.984 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: Incoming command class COMMAND_CLASS_BASIC, endpoint 2
05-Aug-2019 17:01:51.984 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 30: SECURITY not supported
05-Aug-2019 17:01:51.984 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 30: Received COMMAND_CLASS_BASIC V0 BASIC_REPORT
05-Aug-2019 17:01:51.984 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 30: Basic report, value = 255
05-Aug-2019 17:01:51.984 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
05-Aug-2019 17:01:51.985 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Got a value event from Z-Wave network, endpoint=2, command class=COMMAND_CLASS_BASIC, value=255
05-Aug-2019 17:01:51.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=0
05-Aug-2019 17:01:51.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:scene_number, cmdClass=COMMAND_CLASS_SCENE_ACTIVATION, endpoint=0
05-Aug-2019 17:01:51.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:51.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:51.985 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:51.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:51.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_reset, cmdClass=COMMAND_CLASS_METER, endpoint=0
05-Aug-2019 17:01:51.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_power, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
05-Aug-2019 17:01:51.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:alarm_heat, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
05-Aug-2019 17:01:51.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:time_offset, cmdClass=COMMAND_CLASS_CLOCK, endpoint=0
05-Aug-2019 17:01:51.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary1, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=1
05-Aug-2019 17:01:51.986 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:51.987 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:51.987 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:51.987 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current1, cmdClass=COMMAND_CLASS_METER, endpoint=1
05-Aug-2019 17:01:51.987 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:switch_binary2, cmdClass=COMMAND_CLASS_SWITCH_BINARY, endpoint=2
05-Aug-2019 17:01:51.987 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_voltage2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:51.987 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_watts2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:51.987 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_kwh2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:51.987 [TRACE] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 30: Checking channel=zwave:device:4296a94a:node30:meter_current2, cmdClass=COMMAND_CLASS_METER, endpoint=2
05-Aug-2019 17:01:51.988 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Commands processed 1.
05-Aug-2019 17:01:51.988 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 30: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3250ddff.
