The best option is to use Github. The database history is very verbose and not really useful for most users.
If you simply use github, you can see exactly what actually changed where it counts - ie in the binding. It’s what I use - I only use the database history when I’m reviewing changes for approval…
No - this is standard for all devices, and was actually already included in the thing configuration before it was added to the XML (it was injected dynamically, but due to a bug in ESH I ended up adding it statically to all XML).
If the initialisation doesn’t complete, what does the logfile show? This will answer your question.
The “funky stuff in the overview” was the table in the first post of the other thread. It had been pasted in from the PDF manual, which gave it some odd formatting that caused issues when viewing the device in Paper UI. IIRC, Habmin just ignored it entirely. My memory is a little foggy on the specifics, but the change I made was to improve usability of Paper UI for this device, and the change I made should not have affected any functionality of the device.
GH maintains the history for all files, so should be complete unless the files changed names etc. This did happen a while ago when I moved all the XML files from a single folder, into separate folders per manufacturer. This is what you see here (back in March).
If you wanted to go further back you’d have to look at the old file.
That can’t have been made to GH though - or at least, there is no record of it, so I’m not sure on what basis you are saying that the change was made then? If I look at the commit on the 22 July, there is no record of a change to that file.
I would really be surprised if GH can be wrong here.
I found it… was in the commit from 18 Aug. The month time span led me astray. Here is the change I made to the overview…
Before (with funk in the Overview)
Siren<br />
<h2>Inclusion Information</h2>
<ol><li>Have Z-Wave Controller enter inclusion mode.</li>
<li>Pressing tamper key three times within 1.5 seconds to enter the inclusion mode.</li>
<li>After add successful, the LED will light ON 1 second </li> </ol><br />
<h2>Exclusion Information</h2>
<ol><li>Have Z-Wave Controller enter exclusion mode.</li>
<li>Pressing tamper key three times within 1.5 seconds to enter the exclusion mode.</li>
<li>Node ID has been excluded. </li> </ol>
After
Siren<br />
<h1>Overview</h1>
<p>The DCH-Z510 mydlink Z-Wave Siren is a wireless siren.</p> <br />
Looks like the funky table prevented the entire <h1>Overview</h1> section from being exported altogether, which could explain the issues in Paper UI.
