The zwave database shows a bunch of errors for this device (https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/724#parameters) but when I go in to edit them, they aren’t set the way the error says.
Device definition contains errors
Parameter 3 has both read-only and write-only set.
Parameter 4 has both read-only and write-only set.
Parameter 20 has both read-only and write-only set.
Parameter 80 has both read-only and write-only set.
@chris, Can you delete the extra lines for parameter 84 labeled 'delete this line ’
Also, I’m not sure if each endpoint needs a meter_reset or not? It seems difficult to find documentation on this type of stuff.
