maccan
(Marcus_B)
January 23, 2017, 8:24am
1
I have a new zwave device that is not being recognized.
Z-Wave Node 9 (0086:0004:0075:1.2)
Unknown Device
zwave:device:158b570972e:node9
It is the new Aeon labs range extender 6.
Tryed to add it to zwave database from the xml but it only update the existing Aeon labs range extender.
Any suggestions to what i am doing wrong?
Here is the start to the xml file.
<node>
<deviceClass>
<basicDeviceClass>ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>REPEATER_SLAVE</genericDeviceClass>
<specificDeviceClass>BASIC_REPEATER_SLAVE</specificDeviceClass>
</deviceClass>
<homeId>0xee955534</homeId>
<nodeId>9</nodeId>
<version>4</version>
<manufacturer>0x86</manufacturer>
<deviceId>0x75</deviceId>
<deviceType>0x4</deviceType>
chris
(Chris Jackson)
January 26, 2017, 3:34pm
2
Can you provide the rest of it as well ;).
maccan
(Marcus_B)
January 27, 2017, 7:47am
3
chris:
Absolutely, here it is.
<node>
<deviceClass>
</deviceClass>
<nodeId>9</nodeId>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<nodeInformationFrame>
<commandClass>ZWAVE_PLUS_INFO</commandClass>
<commandClass>SWITCH_MULTILEVEL</commandClass>
<commandClass>COLOR</commandClass>
<commandClass>CONFIGURATION</commandClass>
<commandClass>ASSOCIATION</commandClass>
<commandClass>ASSOCIATION_GROUP_INFO</commandClass>
<commandClass>MANUFACTURER_SPECIFIC</commandClass>
<commandClass>VERSION</commandClass>
<commandClass>FIRMWARE_UPDATE_MD</commandClass>
<commandClass>POWERLEVEL</commandClass>
<commandClass>DEVICE_RESET_LOCALLY</commandClass>
</nodeInformationFrame>
<supportedCommandClasses>
<entry>
<configurationCommandClass>
<version>1</version>
<instances>1</instances>
<versionSupported>1</versionSupported>
<configParameters/>
</configurationCommandClass>
</entry>
<entry>
<commandClass>NO_OPERATION</commandClass>
<noOperationCommandClass>
</noOperationCommandClass>
</entry>
<entry>
<deviceResetLocallyCommandClass>
</deviceResetLocallyCommandClass>
</entry>
<entry>
<versionCommandClass>
<version>2</version>
<versionSupported>2</versionSupported>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>4.34</protocolVersion>
<applicationVersion>1.2</applicationVersion>
<hardwareVersion>117</hardwareVersion>
</versionCommandClass>
</entry>
<entry>
<multiLevelSwitchCommandClass>
<isGetSupported>true</isGetSupported>
</multiLevelSwitchCommandClass>
</entry>
<entry>
<firmwareUpdateCommandClass>
</firmwareUpdateCommandClass>
</entry>
<entry>
<powerLevelCommandClass>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</powerLevelCommandClass>
</entry>
<entry>
<commandClass>BASIC</commandClass>
<basicCommandClass>
</basicCommandClass>
</entry>
<entry>
<manufacturerSpecificCommandClass>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>134</deviceManufacturer>
<deviceType>4</deviceType>
<deviceId>117</deviceId>
</manufacturerSpecificCommandClass>
</entry>
<entry>
<associationGroupInfoCommandClass>
<autoSubscribeGroups>
<int>1</int>
</autoSubscribeGroups>
</associationGroupInfoCommandClass>
</entry>
<entry>
<associationCommandClass>
<maxGroups>1</maxGroups>
</associationCommandClass>
</entry>
<entry>
<colorCommandClass>
<supportedColors>
<colorType>BLUE</colorType>
<colorType>RED</colorType>
<colorType>GREEN</colorType>
</supportedColors>
<refreshList/>
<colorMap>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
</colorMap>
</colorCommandClass>
</entry>
<entry>
<zwavePlusCommandClass>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>5</zwPlusRole>
<zwPlusNodeType>0</zwPlusNodeType>
<zwPlusDeviceType>0x1b00</zwPlusDeviceType>
<zwPlusInstallerIcon>0x1b00</zwPlusInstallerIcon>
</zwavePlusCommandClass>
</entry>
</supportedCommandClasses>
<securedCommandClasses/>
<associationGroups>
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<name>Lifeline</name>
<profile1>0x0</profile1>
<profile2>0x1</profile2>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<nodeNeighbors>
<int>1</int>
<int>3</int>
<int>4</int>
<int>6</int>
</nodeNeighbors>
<lastSent>2017-01-20 18:53:23.69 UTC</lastSent>
<lastReceived>2017-01-20 18:53:23.109 UTC</lastReceived>
</node>
maccan
(Marcus_B)
February 7, 2017, 7:38am
4
Have you hade time to look at this?
chris
(Chris Jackson)
February 7, 2017, 4:33pm
5
Sorry - no I’ve not. Given this is only the range extender though it’s not going to actually do anything - it will just add the name.
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/527
I’ve now added it to the database but it needs parameters etc adding - if you are able to add this it would be appreciated.
maccan
(Marcus_B)
February 10, 2017, 10:51am
7
Thank you.
I have now added the parameters, associationGroups and securedCommandClasses. But i do not now how to set up parameter 255 correct.
It needs value 0x55555555.
0xFF (255)
1, Value = 0x55555555、Default = 1、Size = 4
Reset to factory default settings and removed
from the z-wave network
2, Value = 0、Default = 1、Size = 1
Reset all configuration parameters to factory
default settings
chris
(Chris Jackson)
February 10, 2017, 11:29am
8
I would suggest to add 2 parameters -:
default settings
and set them both to write only…
You’ll get an error/warning in the database as the size is different - ignore that and I’ll sort it out…
maccan
(Marcus_B)
February 10, 2017, 1:15pm
9
In the first parameter 255 i can not remove the Option value “Reset all configuration”.
And i can not set the Option Value “Reset to factory default” to 0x55555555.
chris
(Chris Jackson)
February 10, 2017, 1:18pm
10
If you want to remove it, just set it to “DELETE ME” or something and I’ll remove it. Values must be specified in decimal - to set a value of 0x55555555, use 1431655765.
Thanks.
jaydee73
(Stefan)
March 12, 2017, 7:37pm
11
Hi @chris ! I don’t know if my recent issue is related to the problem in this thread. I used my Aeon range extender for several weeks. Today I updated my snapshot installation to the most recent version. After a reboot, the extender doesn’t seem to respond anymore. In Habmin, I could only delete the thing. So I did and also deleted the xml.
After a new discovery the thing was found, but now it’s an unknown device:
Z-Wave Node 15 (0086:0004:0025:1.6)
Unknown Device
Unfortunately, no xml was yet created.
As the device is mains powered, it should fully initialize within seconds.
Do you have any suggestions?
jaydee73
(Stefan)
March 12, 2017, 7:41pm
12
One more thing (I just noticed):
My range extender obviously is another device, not the one mentioned here. Mine seems to be:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/66
But maybe exactly this is the problem as there is an error in the device definitions according to your DB?!
chris
(Chris Jackson)
March 12, 2017, 8:26pm
13
The error in the database just means there are no channels defined since it’s a range extender, and therefore doesn’t do anything (right?).
I would try to restart the binding - just in case it’s related to the inbox issue.
jaydee73
(Stefan)
March 13, 2017, 8:13am
14
Thanks for your fast response @chris !
chris:
Right! I only thought that because of this message in your db:
This device has received the following updates since the last review. Note: Review can not be performed until all errors are removed!
the device probably isn’t fully implemented in your db at the moment. But this assumption could be wrong of course.
chris:
I just did. Unfortunately, it’s still an unknown device. The log says:
2017-03-13 09:06:46.793 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 15: Device discovery could not resolve to a thingType! 0086:0004:0025::1.6
Any further ideas?
chris
(Chris Jackson)
March 13, 2017, 8:57am
15
Currently it’s not exported from the database as there are no channels. The database doesn’t allow me to export devices that don’t have channels - I should change that so we can export this device, but that is why it’s marked as unknown. However, since it doesn’t do anything it won’t impact on the operation of the network - it will work fine, but just not be listed as a thing…
jaydee73
(Stefan)
March 13, 2017, 9:32am
16
Ok, I understand. Thanks Chris!
chebuzz
(David C)
June 10, 2017, 4:46am
17
Hey chris, did you ever change the database so that you can export devices that don’t h ave channels? I just included an Aeon Labs Range Extender 6 into my network and it shows as an unknown device:
Device discovery could not resolve to a thingType! 0086:0104:0075::1.2
I couldn’t find this ID anywhere, although there is one almost identical to it with ID 0086:0004:0075. Does that mean this once is a small revision of that one?
