The device was excluded and re-included with the Aeonlab Z-Stick Gen5 controller (the controller blinked as expected, indicating that the device was excluded / included properly)
After restarting openhab2 I’m getting a warning
grep -i zwave /var/log/openhab2/openhab.log
2017-08-08 21:14:51.684 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 0113:5252:3530::5.21
Habmin shows that the device is not in the database.
@chris
I would like to add the Evolve LOM-15 wall socket to the database, can I be given access?
I tried leaving a message in the site but I’m getting a message: “Please enter security code displayed in the image!” but no image is displayed even if I press refresh
I’ll look at this and can probably fix it - otherwise we can ignore it…
If the device has configuration parameters, then you will need to add them to the database for them to be used. The device will still work without this, but you won’t be able to change the configuration.
@chris I switched the installation repository from Stable to Snapshot, installed the latest snapshot and the LOM-15 works well.
Is it possible to switch the installation repository back to Stable, and use it with the snapshot zwave binding?
Yes, this is possible. You would need to uninstall the binding, then download the snapshot JAR and manually add it to the addons folder. Then in the Karaf console, use the following command to install the serial driver -:
Ok, and for that matter, Is it possible to use the Stable installation repository, with the development zwave binding? (to check secure zwave connection). I want to make sure that the development version doesn’t have breaking changes. Also, what is the roadmap for integration of the zwave Development binding to a Stable/Beta releases (as I remember the plan was to integrate it into the stable release sometime in July/August).
Thanks again.
