ZWAVE device goes online without being plugged in, NAS-WR01ZE
Tags: #<Tag:0x00007f5c956a1870> #<Tag:0x00007f5c956a1578> #<Tag:0x00007f5c956a1398>
i have a problem with a zwave device. The thing status of the device changes from offline to online by itself (at 2020-03-26 02:42:31.830). What is going on?
Is it related to the network heal? How can i change this behavior?
OH 2.5.3 stable
openhab.log
2020-03-26 02:40:00.347 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node2 - TEST-Status ONLINE
2020-03-26 02:40:00.349 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node3 - TEST-Status ONLINE
2020-03-26 02:40:00.350 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node4 - TEST-Status ONLINE
2020-03-26 02:40:00.352 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node5 - TEST-Status ONLINE
2020-03-26 02:40:00.353 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node6 - TEST-Status ONLINE
2020-03-26 02:40:00.354 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node9 - TEST-Status OFFLINE
2020-03-26 02:40:00.355 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node10 - TEST-Status ONLINE
2020-03-26 02:40:00.357 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node11 - TEST-Status OFFLINE
2020-03-26 02:40:00.358 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node12 - TEST-Status ONLINE
2020-03-26 02:40:00.359 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node13 - TEST-Status ONLINE
2020-03-26 02:40:00.360 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node14 - TEST-Status ONLINE
2020-03-26 02:40:00.361 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node15 - TEST-Status ONLINE
2020-03-26 02:42:31.830 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node11 - **changed status ONLINE**
2020-03-26 02:50:00.348 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node2 - TEST-Status ONLINE
2020-03-26 02:50:00.349 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node3 - TEST-Status ONLINE
2020-03-26 02:50:00.350 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node4 - TEST-Status ONLINE
2020-03-26 02:50:00.351 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node5 - TEST-Status ONLINE
2020-03-26 02:50:00.352 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node6 - TEST-Status ONLINE
2020-03-26 02:50:00.353 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node9 - TEST-Status OFFLINE
2020-03-26 02:50:00.354 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node10 - TEST-Status ONLINE
2020-03-26 02:50:00.354 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node11 - TEST-Status ONLINE
2020-03-26 02:50:00.355 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node12 - TEST-Status ONLINE
2020-03-26 02:50:00.356 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node13 - TEST-Status ONLINE
2020-03-26 02:50:00.357 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node14 - TEST-Status ONLINE
2020-03-26 02:50:00.358 [INFO ] [jsr223.jython.Jython_Andi ] - ZWAVE node15 - TEST-Status ONLINE
I have exactly the same problem.
It’s really annoying :frowning:
I’m running OH 2.5.3 stable with ZWave binding snapshot 2.5.4…
Thanks for help - too
@Bruce_Osborne Thanks for adding the tags, I could not add any because of this error …
I think z-wave works but not zwave They cannot figure out what is wrong.
There is a known issue with the binding where it is not correctly setting devices offline. There is an issue open, but I’ve not had the time to look at it.
Thanks a lot, you are doing a great job here! I will test it later with a new version if one appears…
