Thanks sihui, but this one says command=sensor_binary. Am I correct that I just need to replace it with sensor_door leaving the rest as is?
Uwe
Uwe
I don’t have that device, easiest way is to take a look at the database:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/251
so it should be sensor_door
Now I am totally confused. The linked database says sensor_binary in the table at the end. HABmin says sensor_door.
Set up both with different items and take a look in your events.log which one fires
You are looking at the wrong information - although, possibly the only informaiton you can see - maybe. What I think you are looking at is the list of command classes down the left side? This is only the supported command classes - it’s not in any way related to what channels are available. The database then shows Door Sensor under the ALARM command class, and if you are logged in, you will see that this uses sensor_door channel in OH2.
Never realized that there is a difference … good to know.
Yes, maybe I should change this, but that’s how it is at the moment
Thanks guys.
Learning more and more about zwave now
OK, I now successfully added the strips and defined items by only using HABmin.
I just wonder that in Habmin and Sitemaps (also in BasicUI) the status is lost always after a while, sometimes even after minutes - but when the door is opened/closed again the status is shown correctly for a while before disappearing again.
So how can I ensure that I always see the latest status?
Another question is - when the alarm switch is triggered - how to set it back to off?
I used the Switch in HABmin Sitemap (Switch to Off), but when I reload the page it toggles back to On.
Thanks for any help in those topics.
Uwe
I am just guessing but this sounds as if the bindings tries to poll the device status (which is performed on regulary basis i.e. 30 minutes for main powered devices). However the sensative strips are battery powered so they won’t respond to the poll request.
Well, while it is correct that the binding tries to poll the device (it polls every device), and this is needed for some data (eg battery level) this won’t impact the UI. If information is disappearing, then this is highly likely to be something outside of the binding.
The statement above says that reloading the page solves the problem, so I would say that this is a UI issue only.
Hi Chris,
you got my statement concerning reload wrong - it was related to the temper_alarm switch only.
When I manually toggle the tamper_alarm switch to off (after I enforced a real temper_alarm at the sensor which was properly setting the switch to on) and reload the page it toggled back to on after reload.
So I am / was not clear on how to release / confirm a temper_alarm event and set the status back to “off”. It seems to work now as I configured category “Alarm”
For the open/close status information it is even worse.
When I open a door the new status is shown in sitemap on BasicUI. But when I reload the page then the status is gone. When I now close the door the new status is popping up, on reload of the page the status is gone
EDIT:
I just cross-checked what the status for sensor_door is in HABmin sitemap and there the latest status is still displayed while in BasicUI (Default) Sitemap the status is empty and only shown in the moment the sensor status changes but then lost (not shown anymore), once the page is reloaded.
I am on OH2 stable, just for info.
Now I am about to give up. Just restarted openhab service and no starus updates anymore. All showing NULL no more open/close status at all.
Add a format string [%s]
to your item:
before:
Contact your_item_name "your_item_label" <contact> { channel="zwave:device:xxxxxxxx:nodeyy:sensor_door"}
after:
Contact your_item_name "your_item_label [%s]" <contact> { channel="zwave:device:xxxxxxxx:nodeyy:sensor_door"}
If you don’t use text files, you can do that in HABmin as well (through Things → Channels → Edit Item → Labeltext
Don’t. Have a nice motorcycle ride and start fresh after that
I’ll give it a try with the item (and using HABmin as this is the first time I did not define items in .item file).
BTW: Just returned from a 2.000 km ride with Iron Butt now.
I added [%s] to the Label Text in Habmin (without any ") but doesn’t work.
No more open/close Information now in any UI, all on Status NULL except for Battery of one sensor now showing 100.
I have no idea where this instability comes from.
Can try .items Files next. And have to check the logs when opening/closing the doors.
Uwe
I tried a lot, I set-up from scratch, finally everything worked out for 18 hours and today I decided to check if it survives a reboot and - NO!
The strips still show up in HABmin (however now two of them in "Node initialising: REQUEST_NIF).
But all of them have Status NULL on their channels and status does not change when opening / closing the door.
So with the reboot something must have happened destroying my setup somehow.
I don’t know even how I could properly prepare logging to capture the relevant events when trying to set it up from scratch again to reproduce the issue.
Any more ideas? Frustrated!
BR
Uwe
This is normal unless you have persistence to restore the state.
Of course, this isn’t normal, although I’m not sure I have any suggestions as to why it wouldn’t work - sorry.
