I have a fresh install of OH3 with a Gen5+ ZStick on a Pi 3B+. It was time for a fresh install with a new Z-Stick (upgraded 5 to 5+) and a new SD card. All of the devices remained the same. I factory reset them and included them each on the new ZStick.
Oddly on reboot, however, the ZWave devices all go offline and get marked as OFFLINE then DEAD until I physically touch each switch. Then after a certain time they go dead again. Please take a look at nodes 30, 31, 32, 33 for example. There is clearly some kind of timeout happening. The devices are different manufacturers and models.
Can anyone give me a hand here about a way to proceed? I’m at a loss.
It seems the devices do not respond to the poll, so I guess that the binding marks them as unreachable. This initialisation has been the same for a long, long time. You say that you have a fresh install, but you don’t saw what the previous install was, however I don’t think it will have changed and pretty much every command sent is timing out.
I decided to swap out my pi for another one on a whim, and everything
worked afterwards. Same SD card, same Z-Stick. Is it a fluke? Maybe. I’m
afraid to reboot to find out though!
