i am running openhab 2.5.9 in container-station on a qnap. all working fine and after some dificulties i got installed my old zwave stick “zmeeuzb1” and this device also found my Aeotec Multisensor.
i created the items… but the output is always -NaN
all items are numbers except the motion sensor which is a switch…
i get no log info, only that when chaning something on the zwave config of the devices… and they keep online…
any idea ?
Z-Wave Node 003: ZW100 MultiSensor 6 ONLINE
ZW100 MultiSensor 6
zwave:device:bdc1b971:node3
Z-Wave Serial Controller ONLINE
zwave:serial_zstick:bdc1b971
you may have to manually wake up that sensor 20-40 times for all items to register correctly. Most battery devices do not stay awake long enough to register all items. Bring sensor as close to your hub as possible, grab some munchies and a good book, and every couple minutes trigger a device wake up. Wait for it to check in, read a page or two, pop some Pringle’s in your mouth, and repeat.
