Is there any progress on the device? The device itself appears correctly in openHAB, but it sends only data once since start of openHAB (actually it seems I get new data only at openHAB startup). Also in Habmin there’s no data update.
How do I have to configure the device? There’s no configuration parameters neither in Habmin nor PaperUI.
I removed the thing, removed the z-wave binding, restarted openhub, added the z-wave binding and the things again, but still the same behavior.
Sorry for the stupid question: How can I force the local z-wave db to be updated (I have read in other threads that removing the binding and adding it again - in Paper UI) should do the trick. But it didn’t in my case.
What version are you running? Are you using the snapshot version, or the stable version? If you are using the stable version, then it won’t work as it’s just too old.
