I am installing a new system, apt-get install on Debian 9 OpenHAB 2.2.0 release build with aeotec gen5 stick. I have installed zwave and Habmin through PaperUI I currently have 5 nodes: the controller, a door sensor (FGDW002), two roller shutter controllers (FGRM222) and one double switch (FGS223). When I see my network I get this:
I can’t see node 3 (one of the roller shutters) and node 5 and 4 are not meshed nor connected to the controller. However, I am able to actuate on all the nodes from the Uis and state is updated whenever the devices are actuated upon. (Node 2 is the door sensor)
If I try to change a value within Habmin when I save the new values, I get a “pending…” tag that stays forever there (even for mains devices), however, the logs seem to indicate updates are correctly performed, for example:
NODE 5: Configuration update received
NODE 5: Configuration update group_1 to [node_1_0]
NODE 5: Creating new message for application command ASSOCIATIONCMD_SET
Took message from queue for sending. Queue length = 0
Message queued. Queue length = 1. Queue={}
Assembled message buffer = 01 0B 00 13 05 04 85 01 01 01 25 E2 A5
NODE 5: Creating new message for command MULTI_ASSOCIATIONCMD_GET group 1
NODE 5: Sending REQUEST Message = 01 0B 00 13 05 04 85 01 01 01 25 E2 A5
Receive Message = 01 04 01 13 01 E8
Receive queue TAKE: Length=0
Assembled message buffer = 01 04 01 13 01 E8
Process Message = 01 04 01 13 01 E8
Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
NODE 5: Sent Data successfully placed on stack.
Receive Message = 01 07 00 13 E2 00 00 02 0B
Assembled message buffer = 01 09 00 13 E2 00 00 02 00 00 05
Process Message = 01 09 00 13 E2 00 00 02 00 00 05
Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=E2 00 00 02
NODE 5: SendData Request. CallBack ID = 226, Status = Transmission complete and ACK received(0)
NODE 5: Starting initialisation from DONE
Karaf indicates habmin and zwave versions:
210 │ Active │ 80 │ 2.2.0 │ HABmin User Interface
214 │ Active │ 80 │ 2.2.0 │ ZWave Binding
However, when I open Habmin the splash page indicates:
Any help would be greatly appreciated.
