I had a door sensor, that i was pretty happy with:
Properties:
|dbReference|633|
|defaultAssociations|1|
|manufacturerId|0214|
|manufacturerRef|0002:0001,0003:0001|
|modelId|IM-20|
|vendor|Kaipule Technology Co., Ltd.|
|zwave_beaming|true|
|zwave_class_basic|BASIC_TYPE_ROUTING_SLAVE|
|zwave_class_generic|GENERIC_TYPE_SENSOR_NOTIFICATION|
|zwave_class_specific|SPECIFIC_TYPE_NOTIFICATION_SENSOR|
|zwave_deviceid|1|
|zwave_devicetype|2|
|zwave_frequent|false|
|zwave_lastheal|2020-03-01T17:09:52Z|
|zwave_lastwakeup|2020-03-01T17:09:48Z|
|zwave_listening|false|
|zwave_manufacturer|532|
|zwave_neighbours|2,3|
|zwave_nodeid|4|
|zwave_plus_devicetype|NODE_TYPE_ZWAVEPLUS_NODE|
|zwave_plus_roletype|ROLE_TYPE_SLAVE_SLEEPING_REPORTING|
|zwave_routing|true|
|zwave_secure|false|
|zwave_version|6.38|
Items:
Contact DoorSensor01SensorDoor "Door sensor" <door> {channel="zwave:device:819c77dd:node4:sensor_door"}
Switch DoorSensor01AlarmTamper "Tamper alarm" {channel="zwave:device:819c77dd:node4:alarm_tamper"}
Number DoorSensor01BatteryLevel "Doorsensor01 Battery level" <battery> (gBatteries) {channel="zwave:device:819c77dd:node4:battery-level"}
… so i bought two more of the same.
It looks like they were added ok …
2020-03-28 15:29:57.510 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:819c77dd' changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to ONLINE
2020-03-28 15:29:57.517 [hingStatusInfoChangedEvent] - 'zwave:device:819c77dd:node12' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-28 15:29:57.522 [hingStatusInfoChangedEvent] - 'zwave:device:819c77dd:node13' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
Items:
Contact DoorSensor02SensorDoor "Window sensor" <window> (gWindows) {channel="zwave:device:819c77dd:node12:sensor_door"}
Switch DoorSensor02AlarmTamper "Tamper alarm" {channel="zwave:device:819c77dd:node12:alarm_tamper"}
Number DoorSensor02BatteryLevel "Doorsensor02 Battery level" <battery> (gBatteries) {channel="zwave:device:819c77dd:node12:battery-level"}
Contact DoorSensor03SensorDoor "Window sensor" <window> (gWindows) {channel="zwave:device:819c77dd:node13:sensor_door"}
Switch DoorSensor03AlarmTamper "Tamper alarm" {channel="zwave:device:819c77dd:node13:alarm_tamper"}
Number DoorSensor03BatteryLevel "Doorsensor03 Battery level" <battery> (gBatteries) {channel="zwave:device:819c77dd:node13:battery-level"}
But the properties look different, here are the properties for DoorSensor02:
|dbReference|633|
|modelId|IM-20|
|zwave_beaming|true|
|zwave_deviceid|1|
|zwave_devicetype|2|
|zwave_neighbours||
|zwave_nodeid|12|
|zwave_routing|true|
|zwave_secure|false|
|zwave_version|0.0|
Like no zwave_plus and no zwave_version ? That seems off.
So the problem is that the events do not show up in OH. (openHAB 2.5.3 Release Build)
The led on the sensor acts like the DoorSensor01 that is working … but no entries in my event.log
Thank you for your suggestions.
