OH 2.1
binding 2.1 (dev branch)
Fibaro FGMS-001 works fine but in log i see this messages.
i think it’s not normal. Can anyone explain it?
11:55:45.318 [INFO ] [me.event.ThingStatusInfoChangedEvent] - ‘zwave:device:15b7bb97064:node2’ changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to ONLINE
11:55:45.326 [INFO ] [marthome.event.ItemStateChangedEvent] - SensorHallMotion changed from ON to OFF
11:56:07.212 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
11:56:07.236 [INFO ] [me.event.ThingStatusInfoChangedEvent] - ‘zwave:device:15b7bb97064:node2’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
11:56:37.276 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
11:57:07.326 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
11:57:37.377 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
11:58:07.427 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
11:58:37.459 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
11:59:07.498 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
11:59:37.546 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
Here is debug info.
12:09:08.920 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
12:09:08.926 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 2662: Transaction event listener: DONE: DONE ->
12:09:08.939 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
12:09:08.947 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: – To notify – COMPLETE
12:09:08.948 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ********* Transaction Response Complete 2662 –
12:09:08.952 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node Init response (0) COMPLETE
12:09:08.954 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node Init transaction completed with response COMPLETE
12:09:38.955 [DEBUG] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Requesting IsFailedNode status from controller.
12:09:38.957 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@126ad8f
12:09:38.959 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Adding to controller queue
12:09:38.961 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
12:09:38.962 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
12:09:38.964 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
12:09:38.965 [DEBUG] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
12:09:38.969 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 62 02 9B
12:09:38.972 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 62 02 9B
12:09:38.979 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
12:09:38.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
12:09:38.991 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
12:09:38.994 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
12:09:38.996 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2663: Transaction Start type IsFailedNodeID
12:09:38.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
12:09:38.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 2663: [WAIT_RESPONSE] requiresResponse=true callback: 0
12:09:38.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: null
12:09:38.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
12:09:39.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: null
12:09:39.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
12:09:39.001 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
12:09:39.002 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
12:09:39.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Apr 26 12:09:41 YEKT 2017 - 2000ms
12:09:39.006 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
12:09:39.008 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 2663: [WAIT_RESPONSE] requiresResponse=true callback: 0
12:09:39.011 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
12:09:39.011 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding…
12:09:39.014 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Apr 26 12:09:41 YEKT 2017 - 1990ms
12:09:39.018 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
12:09:39.021 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 62 01 99
12:09:39.026 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
12:09:39.026 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Apr 26 12:09:41 YEKT 2017 - 1977ms
12:09:39.030 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
12:09:39.034 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
12:09:39.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
12:09:39.040 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2663: [WAIT_RESPONSE] requiresResponse=true callback: 0
12:09:39.042 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
12:09:39.046 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 2663: [WAIT_RESPONSE] requiresResponse=true callback: 0
12:09:39.052 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
12:09:39.055 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
12:09:39.056 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2663: Transaction COMPLETED
12:09:39.058 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2663: TransactionAdvance ST: DONE
12:09:39.060 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2663: TransactionAdvance WT: null {}
12:09:39.062 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2663: TransactionAdvance RX: Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
12:09:39.064 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2663: TransactionAdvance TO: DONE
12:09:39.066 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 71ms
12:09:39.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 2663: Transaction completed
12:09:39.070 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:2663 DONE
12:09:39.075 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
12:09:39.076 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 2663: Transaction event listener: DONE: DONE ->
12:09:39.077 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
12:09:39.080 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: – To notify – COMPLETE
12:09:39.081 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ********* Transaction Response Complete 2663 –
12:09:39.083 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node Init response (0) COMPLETE
i tried to heal device and got this
12:26:27.074 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
12:26:49.069 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Configuration update received
12:26:49.167 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Configuration update action_heal to -232323
12:26:49.170 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Starting heal on node!
12:26:49.174 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Can not start heal as initialisation is not complete (FAILED_CHECK).
