ariela
(Andrea Riela)
March 24, 2018, 10:34pm
1
Hi folks,
I have a question for the owners of this zwave wall plug.
7 properties can be configured, 3 of those are:
Sensor (power)
Electric meter (kWh)
Electric meter (watts)
If I well understood, the first one is the old (OH1) “command=sensor_multilevel”.
The second should be the old (OH1) “command=meter”
is that correct? and what is the third? is is exactly the n.2 n watts instead of kWh?
Thanks for your support
Andrea
5iver
(Scott Rushworth)
March 24, 2018, 11:07pm
2
I do not have this plug. But if you are looking for the channels, go into PaperUI> Configuration> Things and select the Thing. Under Channels, you will find the channel definition and a button to copy it to your clipboard and paste into an items file. Another way is to look into the device database . There were two others, but that was for the latest firmware… they might have different channels.
ariela
(Andrea Riela)
March 25, 2018, 8:57am
3
Thanks for your answer @5iver
I’ve found another thread about this piece:
Hi everybody,
I am using a Fibaro Wall Plug and started configuring the Parameters with Habmin. There I saw, that I have two different items, first one called Sensor (power) Energy Consumption (SensorPower) and second one Electric meter (watts) (ElectricMeterWatts). I thought that both of them show me the actual power consumption, but they are displaying different values (see picture).
[image]
Can somebody explain me the difference between the two items? I could not find any information at th…
I will follow there.
There are some discrepancies and I need to understand better the differences between the 3 properties.
thanks
Andrea
