* OH2 Version: 2.0.0 stable
* Binding Version (if SNAPSHOT, provide compile tim…e as found on the filename in the console): 2.0.0 stable
If the problem is associated with a device, please provide the following -:
* Device name: FGSD-002
* Device version:
* Link to [database](http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/129):
The smoke detector triggers various false alarm during wakeup.
A real alarm triggers the alarm three times.
During wakeup, the smoke detector sends notification messages for an alarm, e.g.:
`01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76`
In case of a real alarm the detector sends three messages:
01 0F 00 04 08 04 09 71 05 00 00 00 FF 07 03 00 7E
All three messages triggers an update "ON" to the linked channel.
Log of "false" alarm:
2017-01-29 21:51:10.673 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76
2017-01-29 21:51:10.673 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 06 00 00 02 00 00 E1
2017-01-29 21:51:10.678 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=06 00 00 02
2017-01-29 21:51:10.681 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 4: SendData Request. CallBack ID = 6, Status = Transmission complete and ACK received(0)
2017-01-29 21:51:10.685 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=4, callback=6, payload=04 05 71 04 00 07 03
2017-01-29 21:51:10.691 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=06 00 00 02
2017-01-29 21:51:10.694 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=6, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2017-01-29 21:51:10.698 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-29 21:51:10.707 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76
2017-01-29 21:51:10.712 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76
2017-01-29 21:51:10.716 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 09 71 05 00 00 00 FF 07 03 00
2017-01-29 21:51:10.722 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DYNAMIC_VALUES)
2017-01-29 21:51:10.725 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class ALARM
2017-01-29 21:51:10.728 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Received ALARM command V5
2017-01-29 21:51:10.732 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Process NOTIFICATION_REPORT V5
2017-01-29 21:51:10.736 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: NOTIFICATION report - 0 = 0, event=3, status=255
2017-01-29 21:51:10.739 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Alarm Type = BURGLAR (0)
2017-01-29 21:51:10.743 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-01-29 21:51:10.746 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-01-29 21:51:10.750 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-01-29 21:51:10.754 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-29 21:51:10.758 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-29 21:51:10.761 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 3, type OnOffType
2017-01-29 21:51:10.765 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:ffabd0a2:node4:alarm_tamper to ON [OnOffType]
2017-01-29 21:51:10.775 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-29 21:51:10.777 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-29 21:51:10.778 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-29 21:51:10.779 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating update 'ON' for item 'ZWave_Fire_Ian_Tamper' to handler for channel 'zwave:device:ffabd0a2:node4:alarm_general'
2017-01-29 21:51:10.781 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=4, callback=6, payload=04 05 71 04 00 07 03
2017-01-29 21:51:10.784 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 09 71 05 00 00 00 FF 07 03 00
2017-01-29 21:51:10.785 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=6, expected=ApplicationCommandHandler, cancelled=false transaction complete!
2017-01-29 21:51:10.798 [DEBUG] [ntime.internal.engine.RuleEngineImpl] - Executing rule 'Warnings'
2017-01-29 21:51:10.788 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for ZWave_Fire_Ian_Tamper
2017-01-29 21:51:10.804 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'ZWave_Fire_Ian_Tamper' with state 'ON' in mapdb database
Log of real alarm:
2017-01-30 21:34:27.570 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76
2017-01-30 21:34:27.580 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-30 21:34:27.584 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76
2017-01-30 21:34:27.589 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76
2017-01-30 21:34:27.594 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 09 71 05 00 00 00 FF 07 03 00
2017-01-30 21:34:27.597 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
2017-01-30 21:34:27.599 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
2017-01-30 21:34:27.602 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@d85c69 already registered
2017-01-30 21:34:27.605 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class ALARM
2017-01-30 21:34:27.608 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Received ALARM command V5
2017-01-30 21:34:27.610 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Process NOTIFICATION_REPORT V5
2017-01-30 21:34:27.613 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: NOTIFICATION report - 0 = 0, event=3, status=255
2017-01-30 21:34:27.616 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Alarm Type = BURGLAR (0)
2017-01-30 21:34:27.619 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-01-30 21:34:27.622 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-01-30 21:34:27.625 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-01-30 21:34:27.629 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.632 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.636 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 3, type OnOffType
2017-01-30 21:34:27.639 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:ffabd0a2:node4:alarm_tamper to ON [OnOffType]
2017-01-30 21:34:27.644 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.647 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating update 'ON' for item 'ZWave_Fire_Ian_Tamper' to handler for channel 'zwave:device:ffabd0a2:node4:alarm_general'
2017-01-30 21:34:27.648 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.650 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.660 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 7: Transaction not completed: node address inconsistent. lastSent=7, incoming=255
2017-01-30 21:34:27.663 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 08 04 09 71 05 00 00 00 FF 07 03 00 7E
2017-01-30 21:34:27.667 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for ZWave_Fire_Ian_Tamper
2017-01-30 21:34:27.672 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'ZWave_Fire_Ian_Tamper' with state 'ON' in mapdb database
2017-01-30 21:34:27.674 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for warnings
2017-01-30 21:34:27.677 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'warnings' with state 'ON' in mapdb database
2017-01-30 21:34:27.678 [DEBUG] [ntime.internal.engine.RuleEngineImpl] - Executing rule 'Warnings'
2017-01-30 21:34:27.694 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-30 21:34:27.699 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0F 00 04 08 04 09 71 05 00 00 00 FF 07 03 00 7E
2017-01-30 21:34:27.709 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76
2017-01-30 21:34:27.714 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0F 00 04 08 04 09 71 05 00 00 00 FF 07 03 00 7E
2017-01-30 21:34:27.726 [INFO ] [g.eclipse.smarthome.model.script.BOT] - Group 'Warning' received update [warnings (Type=GroupItem, Members=2, State=ON, Label=Warnungen, Category=siren)].
2017-01-30 21:34:27.733 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=08 04 09 71 05 00 00 00 FF 07 03 00
2017-01-30 21:34:27.741 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
2017-01-30 21:34:27.744 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
2017-01-30 21:34:27.747 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@d85c69 already registered
2017-01-30 21:34:27.750 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class ALARM
2017-01-30 21:34:27.753 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Received ALARM command V5
2017-01-30 21:34:27.756 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Process NOTIFICATION_REPORT V5
2017-01-30 21:34:27.759 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: NOTIFICATION report - 0 = 0, event=3, status=255
2017-01-30 21:34:27.761 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Alarm Type = BURGLAR (0)
2017-01-30 21:34:27.764 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-01-30 21:34:27.767 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-01-30 21:34:27.770 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-01-30 21:34:27.774 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.776 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.779 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 3, type OnOffType
2017-01-30 21:34:27.782 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:ffabd0a2:node4:alarm_tamper to ON [OnOffType]
2017-01-30 21:34:27.788 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.789 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.791 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.791 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating update 'ON' for item 'ZWave_Fire_Ian_Tamper' to handler for channel 'zwave:device:ffabd0a2:node4:alarm_general'
2017-01-30 21:34:27.792 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 7: Transaction not completed: node address inconsistent. lastSent=7, incoming=255
2017-01-30 21:34:27.794 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-30 21:34:27.795 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for warnings
2017-01-30 21:34:27.798 [DEBUG] [ntime.internal.engine.RuleEngineImpl] - Executing rule 'Warnings'
2017-01-30 21:34:27.798 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76
2017-01-30 21:34:27.801 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'warnings' with state 'ON' in mapdb database
2017-01-30 21:34:27.803 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0F 00 04 00 04 09 71 05 00 00 00 FF 07 03 00 76
2017-01-30 21:34:27.804 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for ZWave_Fire_Ian_Tamper
2017-01-30 21:34:27.817 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'ZWave_Fire_Ian_Tamper' with state 'ON' in mapdb database
2017-01-30 21:34:27.824 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 09 71 05 00 00 00 FF 07 03 00
2017-01-30 21:34:27.828 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
2017-01-30 21:34:27.834 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
2017-01-30 21:34:27.837 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@d85c69 already registered
2017-01-30 21:34:27.841 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class ALARM
2017-01-30 21:34:27.842 [INFO ] [g.eclipse.smarthome.model.script.BOT] - Group 'Warning' received update [warnings (Type=GroupItem, Members=2, State=ON, Label=Warnungen, Category=siren)].
2017-01-30 21:34:27.844 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Received ALARM command V5
2017-01-30 21:34:27.847 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Process NOTIFICATION_REPORT V5
2017-01-30 21:34:27.850 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: NOTIFICATION report - 0 = 0, event=3, status=255
2017-01-30 21:34:27.853 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 4: Alarm Type = BURGLAR (0)
2017-01-30 21:34:27.856 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2017-01-30 21:34:27.859 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-01-30 21:34:27.862 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-01-30 21:34:27.866 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.869 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.872 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 3, type OnOffType
2017-01-30 21:34:27.875 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:ffabd0a2:node4:alarm_tamper to ON [OnOffType]
2017-01-30 21:34:27.880 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.882 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.883 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2017-01-30 21:34:27.883 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating update 'ON' for item 'ZWave_Fire_Ian_Tamper' to handler for channel 'zwave:device:ffabd0a2:node4:alarm_general'
2017-01-30 21:34:27.885 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 7: Transaction not completed: node address inconsistent. lastSent=7, incoming=255
2017-01-30 21:34:27.891 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for warnings
2017-01-30 21:34:27.900 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'warnings' with state 'ON' in mapdb database
2017-01-30 21:34:27.906 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for ZWave_Fire_Ian_Tamper
2017-01-30 21:34:27.906 [DEBUG] [ntime.internal.engine.RuleEngineImpl] - Executing rule 'Warnings'
2017-01-30 21:34:27.912 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'ZWave_Fire_Ian_Tamper' with state 'ON' in mapdb database
2017-01-30 21:34:27.925 [INFO ] [g.eclipse.smarthome.model.script.BOT] - Group 'Warning' received update [warnings (Type=GroupItem, Members=2, State=ON, Label=Warnungen, Category=siren)].
2017-01-30 21:34:28.020 [INFO ] [g.eclipse.smarthome.model.script.BOT] - LastUpdate (Rauchmelder (Ian) manipuliert): 2017-01-30T21:34:27.908+01:00
2017-01-30 21:34:28.033 [INFO ] [g.eclipse.smarthome.model.script.BOT] - LastUpdate (Rauchmelder (Treppe) manipuliert): 2017-01-30T04:19:37.425+01:00
2017-01-30 21:34:28.041 [DEBUG] [g.eclipse.smarthome.model.script.BOT] - Triggered by ZWave_Fire_Ian_Tamper (Type=SwitchItem, State=ON, Label=Rauchmelder (Ian) manipuliert, Category=siren, Groups=[Ian, warnings])
2017-01-30 21:34:28.130 [INFO ] [g.eclipse.smarthome.model.script.BOT] - LastUpdate (Rauchmelder (Ian) manipuliert): 2017-01-30T21:34:27.908+01:00
2017-01-30 21:34:28.142 [INFO ] [g.eclipse.smarthome.model.script.BOT] - LastUpdate (Rauchmelder (Treppe) manipuliert): 2017-01-30T04:19:37.425+01:00
2017-01-30 21:34:28.150 [DEBUG] [g.eclipse.smarthome.model.script.BOT] - Triggered by ZWave_Fire_Ian_Tamper (Type=SwitchItem, State=ON, Label=Rauchmelder (Ian) manipuliert, Category=siren, Groups=[Ian, warnings])
2017-01-30 21:34:28.218 [INFO ] [g.eclipse.smarthome.model.script.BOT] - LastUpdate (Rauchmelder (Ian) manipuliert): 2017-01-30T21:34:27.908+01:00
2017-01-30 21:34:28.235 [INFO ] [g.eclipse.smarthome.model.script.BOT] - LastUpdate (Rauchmelder (Treppe) manipuliert): 2017-01-30T04:19:37.425+01:00
2017-01-30 21:34:28.241 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 08 04 07 9C 02 04 00 FF 00 00 98
2017-01-30 21:34:28.245 [DEBUG] [g.eclipse.smarthome.model.script.BOT] - Triggered by ZWave_Fire_Ian_Tamper (Type=SwitchItem, State=ON, Label=Rauchmelder (Ian) manipuliert, Category=siren, Groups=[Ian, warnings])
2017-01-30 21:34:28.258 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-30 21:34:28.261 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 04 08 04 07 9C 02 04 00 FF 00 00 98
2017-01-30 21:34:28.265 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0D 00 04 08 04 07 9C 02 04 00 FF 00 00 98
2017-01-30 21:34:28.281 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 04 07 9C 02 04 00 FF 00 00 90
2017-01-30 21:34:28.287 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=08 04 07 9C 02 04 00 FF 00 00
2017-01-30 21:34:28.307 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
2017-01-30 21:34:28.308 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
2017-01-30 21:34:28.309 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@d85c69 already registered
2017-01-30 21:34:28.311 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class SENSOR_ALARM
2017-01-30 21:34:28.312 [DEBUG] [ndclass.ZWaveAlarmSensorCommandClass] - NODE 4: Received SENSOR_ALARM command V1
2017-01-30 21:34:28.313 [DEBUG] [ndclass.ZWaveAlarmSensorCommandClass] - NODE 4: Alarm Report: Source=4, Type=General(0), Value=255
2017-01-30 21:34:28.314 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmSensorValueEvent
2017-01-30 21:34:28.316 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveAlarmSensorValueEvent
2017-01-30 21:34:28.317 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_ALARM, value = 255
2017-01-30 21:34:28.336 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 7: Transaction not completed: node address inconsistent. lastSent=7, incoming=255
2017-01-30 21:34:28.340 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-30 21:34:28.351 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 04 00 04 07 9C 02 04 00 FF 00 00 90
2017-01-30 21:34:28.356 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0D 00 04 00 04 07 9C 02 04 00 FF 00 00 90
2017-01-30 21:34:28.377 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 07 9C 02 04 00 FF 00 00
2017-01-30 21:34:28.391 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
2017-01-30 21:34:28.394 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
2017-01-30 21:34:28.398 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@d85c69 already registered
2017-01-30 21:34:28.403 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class SENSOR_ALARM
2017-01-30 21:34:28.421 [DEBUG] [ndclass.ZWaveAlarmSensorCommandClass] - NODE 4: Received SENSOR_ALARM command V1
2017-01-30 21:34:28.426 [DEBUG] [ndclass.ZWaveAlarmSensorCommandClass] - NODE 4: Alarm Report: Source=4, Type=General(0), Value=255
2017-01-30 21:34:28.430 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmSensorValueEvent
2017-01-30 21:34:28.435 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveAlarmSensorValueEvent
2017-01-30 21:34:28.439 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_ALARM, value = 255
