Thanks. This shows that the pollingPeriod is not set, so it will use the default of 3600.
My guess is that there is a bug in the UI and it’s not saving this correctly
This ties up with the statement above - it doesn’t seem to be being saved by the UI - or when it is saved from the UI side, it is rejected by the core so it’s not stored.
Correct.
I will edit this later and let you know.
I did edit the JSON using the put to add binding_pollperiod and verified with Zniffer 30 minute polls are no more, so I think what is going on has been answered. I have not rebooted, but expect the additions to stick.
As to why, I did upgrade to OH3 from OH2.5 in December using the openhabian script. I noticed, for me the changes to binding_pollperiod I made to “things” after the upgrade are included in the JSON. It was only the items transitioned to OH3. Still not a “why”, but simply editing the thing in the UI might be all that is needed.
I don’t know if I should add “solved”, but between @chris and @Dadman the cause and cure (or at least a workaround) are contained in this thread (IMO).
Bob
It can easily be checked and i will try it later.
I will edit the polling period in the ui and check if the configuration is updated. After a restart the log should contain the initialisation with the new period. Then its not a bug.
Otherwise i will edit the json by hand.
So i reconfigured all my devices from the UI. Just replace the last digit with the same number and save. (86400 -> 8640 -> 86400 -> Save) This causes an update to the jsonDB with the polling period.
The Log shows the initialisation of the devices with this period.
I will check the log tomorrow evening, but i am sure this will work.
Don’t know if this is an problem with adding new things or caused by the migration from OH2.5 to 3.0.
I will add a new device to my Z Wave network in the next two weeks and check this.
Thanks to all for the help!
Update: I checked the log today an can confirm the polling every 30 minutes is gone. Function is normal for all devices.
