I am new to openHAB and in my first week im setting up a system.
I am using Rasberry PI 3 with a Razberry module and, Openhabian package 2.2
I have already included other Bindings without any problem, but with ZWave I am having problems.
I was able to install the Razberry module and it was recocgnized correctly and is online.
The problem I have is, that I can not include any device.
I see, that the Razberry module is going into inclusion mode and I have tried different devices(Fibaro WallSwitch and WallPlug) without success. I have tried diffrent ways to set the devices in inclusion mode as well, but nothing helped.
I have set the log level for the Binding to DEBUG.
From other forums I have seen, that one reason could be, that the Razberry is not using the correct frequency.
I am located in the EU and have bought it here. But I also do not know how to check if the Razberry is an US or Canadian Device which might use different frequencies.
Thanks in advance for any help.
Here is a sniplet of two Inclusions I have tried:
2017-12-27 14:37:05.804 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-12-27 14:37:05.808 [DEBUG] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!
2017-12-27 14:37:05.813 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Starting ZWave inclusion scan for zwave:serial_zstick:63b42b5b
2017-12-27 14:37:05.818 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller start inclusion - mode 2
2017-12-27 14:37:05.823 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Setting controller into INCLUSION mode, highPower:true networkWide:true.
2017-12-27 14:37:05.828 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
_2017-12-27 14:37:05.832 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A C1 01 70 _
2017-12-27 14:37:05.832 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 0. Queue={}
_2017-12-27 14:37:05.836 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A C1 01 70 _
_2017-12-27 14:37:05.842 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 01 00 00 B2 _
2017-12-27 14:37:05.907 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
_2017-12-27 14:37:05.912 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 01 00 00 B2 _
_2017-12-27 14:37:05.916 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 01 00 00 B2 _
_2017-12-27 14:37:05.919 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00 _
2017-12-27 14:37:05.922 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Learn ready.
2017-12-27 14:37:05.924 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
_2017-12-27 14:37:05.968 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=C1 01 _
_2017-12-27 14:37:05.976 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00 _
2017-12-27 14:37:05.978 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false transaction complete!
2017-12-27 14:37:05.980 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-12-27 14:37:05.983 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 106ms/299ms.
2017-12-27 14:37:35.816 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-12-27 14:37:35.820 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2017-12-27 14:37:35.823 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-12-27 14:37:35.825 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 0. Queue={}
_2017-12-27 14:37:35.827 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 01 B4 _
_2017-12-27 14:37:35.830 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 01 B4 _
2017-12-27 14:37:35.833 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller end inclusion
_2017-12-27 14:37:35.943 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 06 00 00 B5 _
2017-12-27 14:37:35.977 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
_2017-12-27 14:37:35.981 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 06 00 00 B5 _
_2017-12-27 14:37:35.983 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 06 00 00 B5 _
_2017-12-27 14:37:35.985 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00 _
2017-12-27 14:37:35.986 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
2017-12-27 14:37:35.989 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
_2017-12-27 14:37:35.993 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=05 01 _
_2017-12-27 14:37:35.999 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00 _
2017-12-27 14:37:36.002 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false transaction complete!
2017-12-27 14:37:36.004 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-12-27 14:37:36.007 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 149ms/299ms.
2017-12-27 14:40:12.004 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-12-27 14:40:12.007 [DEBUG] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!
2017-12-27 14:40:12.010 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Starting ZWave inclusion scan for zwave:serial_zstick:63b42b5b
2017-12-27 14:40:12.012 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller start inclusion - mode 2
2017-12-27 14:40:12.014 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Setting controller into INCLUSION mode, highPower:true networkWide:true.
2017-12-27 14:40:12.017 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-12-27 14:40:12.017 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
_2017-12-27 14:40:12.020 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A C1 01 70 _
_2017-12-27 14:40:12.023 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A C1 01 70 _
_2017-12-27 14:40:12.030 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 01 00 00 B2 _
2017-12-27 14:40:12.077 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
_2017-12-27 14:40:12.081 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 01 00 00 B2 _
_2017-12-27 14:40:12.083 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 01 00 00 B2 _
_2017-12-27 14:40:12.085 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00 _
2017-12-27 14:40:12.087 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Learn ready.
2017-12-27 14:40:12.089 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
_2017-12-27 14:40:12.113 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=C1 01 _
_2017-12-27 14:40:12.117 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00 _
2017-12-27 14:40:12.119 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false transaction complete!
2017-12-27 14:40:12.120 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-12-27 14:40:12.122 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 75ms/299ms.
2017-12-27 14:40:42.010 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-12-27 14:40:42.013 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2017-12-27 14:40:42.018 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-12-27 14:40:42.019 [DEBUG] [ve.internal.protocol.ZWaveController] - Ending inclusion mode.
_2017-12-27 14:40:42.024 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 01 B4 _
2017-12-27 14:40:42.030 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 0. Queue={}
_2017-12-27 14:40:42.029 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 01 B4 _
2017-12-27 14:40:42.033 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller end inclusion
2017-12-27 14:40:42.037 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-12-27 14:40:42.040 [DEBUG] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!
_2017-12-27 14:40:42.145 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 06 00 00 B5 _
2017-12-27 14:40:42.179 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
_2017-12-27 14:40:42.182 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 06 00 00 B5 _
_2017-12-27 14:40:42.187 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 06 00 00 B5 _
_2017-12-27 14:40:42.192 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00 _
2017-12-27 14:40:42.197 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
2017-12-27 14:40:42.205 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
_2017-12-27 14:40:42.213 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=05 01 _
_2017-12-27 14:40:42.217 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00 _
2017-12-27 14:40:42.222 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false transaction complete!
2017-12-27 14:40:42.226 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-12-27 14:40:42.231 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 174ms/299ms.
