I only added the database entry to OH2. OH1 doesn’t use the database other than for configuration, but as items are manually configured in OH1, it does not require any input from the database in any way.
I couldn’t easily tell this from the log as it didn’t contain the packet information, but I could see many different parameters being received. If you can provide a full debug log I’ll take a look.
Normally multi-channel data is provided also in the root endpoint as well as the other endpoints. Since you don’t say how you have configured your items I don’t know how this is works in your system…
