I was hoping you would read see that bottom part as well.
Glad you got it working and please click the square box on post that provided the solution to mark topic as solved.
I also had crossing linking, because on my example, wallswitch status change when outlet button was pressed, but outlet do not change when wallswitch is pressed .
Switch Wallplug_Lum1 "PC LUM1" <poweroutlet> { channel="zwave:device:9a3c3177:node4:switch_binary", channel="zwave:device:9a3c3177:node9:switch_binary1" [profile="follow"] , autoupdate="true" }
Switch Wallplug_Lum2 "PC LUM2" <poweroutlet> { channel="zwave:device:9a3c3177:node6:switch_binary", channel="zwave:device:9a3c3177:node9:switch_binary2" [profile="follow"] , autoupdate="true" }
//Switch WallSwitchA_1 "Inter A_1" <wallswitch> { channel="zwave:device:9a3c3177:node9:switch_binary" }
Switch WallSwitchA_2 "Inter A_2" <wallswitch> { channel="zwave:device:9a3c3177:node9:switch_binary2", channel="zwave:device:9a3c3177:node6:switch_binary" [profile="follow"] , autoupdate="true" }
Switch WallSwitchA_1 "Inter A_1" <wallswitch> { channel="zwave:device:9a3c3177:node9:switch_binary1", channel="zwave:device:9a3c3177:node4:switch_binary" [profile="follow"] , autoupdate="true" }
Switch PC_Michelle "PC Michelle" <network> { channel="network:device:192_168_0_92:online", autoupdate="true" }
I still have a strange problem with BASIC UI, absolutly nothing change on it, i have to refresh screen manualy to get update .
When i use openhab phone app, select my sitemap, work fine.
What the matter ?
Best regards.
Try another browser or clean the browers cache and see if that helps.
Have a look in your openhab.log for messages about sitemap file at load time.
Hi, I have clean it, nothing inside , tried on another browser and work prefectly, sorry
Perhaps you could tell us what browser you were having trouble with, maybe something could be done about it?
Yes , chrome on windows 10 Laptop, but need to clean cache and check again.
Will try later on another laptop, and give news about that.
Best regards.[quote=“rossko57, post:26, topic:91545, full:true”]
[/quote]
As you expected … work perfectly now.
