But as I said earlier, the device doesn’t receive notifications in group 4 - association groups are for sending notifications. I just looked at the manual, and it also says this so I doubt it will work…
Actually, as this is a battery sensor, it can’t receive notifications in any case…
I also see you added the same channel to the wall plug - if I understand the wall plug docs correctly, I’m not sure it supports the BURGLAR notification, or if it does, then it can’t differentiate this alarm at least -:
Reaction to alarms.
Define Z-Wave network alarms to which the Wall Plug will respond.
Default setting: 63
Available settings: 0 - 63.
1 - general alarm,
2 - smoke alarm,
4 - CO alarm,
8 - CO2 alarm,
16 - high temperature alarm,
32 - flood alarm,
63 - device responds to all types of alarm frames
It seems best to align the channel with these options I guess so that the user can differentiate them in some way (although I think they all do the same thing with the LED, right?).
sorry
I focus on the wallplug for the moment … there I think it should work … (smoke sensor is unlikeley as you said a battery device wont receive incoming notifications)
the debug shows not too much more
19:50:58.463 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Command received zwave:device:15348538564:node7:notification_send --> 1
19:50:58.464 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: No messages returned from converter
19:50:58.467 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'node7_sendnoti' received command 1
I set the the Item for the “send_notification” channel to 1 … which should be resolved to Smoke
parameter 63 of the plug is configured to let the LED flash when a incoming alarm is catched.
