mhh
34 = set to react to all alarms
35 = set to no reaction as this triggers the whole plug to turn on / off / cycle
I only wanted the LED ring to flash by parameter 63… however I will also try with parameter 35 to see if maybe parameter 63 only works when 35 is set aswell
Ok I tried with also Param 35 changed to react to alarms.
Neither the state of the plug nor the led ring reacts to the incoming value 1
I am not sure if the stuff I added to the DB is maybe the issue… I didnt get the syntax fully
when I set the item to Value 1 the SMOKE event is parsed? what is the :1 after SMOKE ?
