Zwave Log Viewer
I used the Z-wave log viewer on a problem I am having and wanted community feedback, but can’t seem to figure out how to get the result in a .jpg file that I can upload. I could attach the raw .txt file, but I would like to do better. I have seen the color coded results in many other postings, so I must be missing something. All my attempts via googling HTML to JPG have failed so far.
Upload your log file here and enjoy.
https://www.cd-jackson.com/index.php/openhab/zwave-log-viewer
Thanks for the fast answer, however, I have it that far. I wanted to get the color coded result in a post here on the forum. Everything I tried drops the nice format and colors and is worse that the raw log file
Did you see the color coded result? I think most people use a screen capture utility such as snipping tool to save it as a graphic.
Here is more debugging information.
https://www.cd-jackson.com/index.php/openhab/5-zwave-debugging-openhab
What sort of issues are you having?
If you’re on a Mac, Monosnap rocks.
Windows has the Snipping Tool, which was recently replaced by Snip & Sketch.
Ok Thanks. Managed to get it in a png file. It is amazing I have made it this far. Will post the actual problem under a different subject line. Basically I am looking for a rule trigger for a Zwave device that does not change status.
If you have a Mac, there is a key sequence that does this out of the box -:
