is it possible to send manually payload like
Data=‘0x71 0x5 0x0 0x0 0x0 0x0 0x6 0x16 0x0 0x0’ to a specific Node?
Would like to find out the correct events for sending Notifications without reconfiguring them over and over in the DB.
There a mutlipley manuals with irritating different events and types for a siren device.
mhhh
ok I am struggling a bit with transferring this: Guides – Vesternet (see different payloads for sounds at the end of the page)
into something like this:
I think your Config in the DB the event 1 is actually referring when the item is set to the value it triggers
SMOKE with Notification Message 0x01 which event number 1, 2, 3 etc. assign e.g. SMOKE:1 to is acutally not relevant?
where is the definition which hex values SMOKE, ACCESS_CONTROL, etc. are resolved to?
ok I think I understood the most from above. only the event enumeration is still open.
I still think its not relevant
e.g.
event1=SMOKE:1 resolves to 0x1:0x1
I could also just set
event2=SMOKE:1
understood that.
added all channels that are documented to the config from different manuals to find out which are actually really work.
I will remove the non working from the config again to get things clean.
however there seems to be a character limit to the config field which is only visible after “saving”. the input was cut then at 256 chars
is that limit intented?
