Hi
My MCOHome touch panel devices (2 and 4 way) are showing as unknown devices. Can someone help me to add them?
Regards
Johan
Hi
Regards
Johan
What node is for what device. Also, what are the actual model numbers for these devices?
Cheers
Chris
Hi
Node 2 is a two way switch (http://www.pepper1.net/zwavedb/device/597)
Node 7 is a four way switch (http://www.pepper1.net/zwavedb/device/577)
Regards
Johan
I’ve added them -:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/433
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/434
They will need any association groups or configuration parameters adding to the database - if you can do this it would be appreciated.
Thanx Chris.
Sent you a mail, asking for editing rights to the database
Regards
Johan
Thanks - I’ve updated your access…
Once the database is ok, I’ll publish the changes and trigger a build - once that is done you should be able to update. I normally do this most days when something has changed…
Database is updated. I can’t find any configuration parameters so I didn’t update them.
Again Chris, thanx for your help
Regards
Johan
Looks good - thanks. I’ll update the binding later this evening so if you grab tomorrows snapshot, hopefully it will be recognised .
Cheers
Chris
Works like a sharm
Regards
Johan
Great - glad to hear
