Hi there,
i just had a problem with my fibaro motion sensor, so i send it back to amazon and got a new one.
As the first sensor wasn´t working anymore, i had to manually delete the Node.
I did this by plugging the Zwave Stick (ZME-UZB1) into my Windows Notebook and deleting the Node with Zensys.
Then i added the new sensor to my network and plugged the Zwave Stick back to my Raspberry Pi3.
The Pi3 was off while doing this.
Now i checked the persistence and deleted all infos from the old sensor, as i thought it would be an good idea to clean up.
Then i checked the OpenHAB website but there wasn´t any sensor data …
Somethin i noticed in the HABmin interface, is the Last Packet Sent/Recieved Info.
It says NEVER …
When i try to heal the Node, the OpenHAB log says:
(I´ve only clicked once …)
2016-10-22 14:51:31.080 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 1: NodeNeighborUpdate FAILED
2016-10-22 14:51:31.114 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 1: NodeNeighborUpdate FAILED
2016-10-22 14:51:31.146 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 1: NodeNeighborUpdate FAILED
2016-10-22 14:51:31.178 [ERROR] [NodeNeighborUpdateMessageClass] - NODE 1: NodeNeighborUpdate FAILED
Here´s my current setup:
http://community-openhab-org.s3-eu-central-1.amazonaws.com/original/2X/c/c5e177d062e8568ff352234a48fe84a7f079e2f4.png
http://community-openhab-org.s3-eu-central-1.amazonaws.com/original/2X/8/8017775190bdd1acc0d220f733de1bc4cecb8c10.png
/* Fibaro Motion Sensor */
Number itmFIBmotion2 "Bewegung: [%s]" <bewegung> {zwave="2:command=sensor_binary"}
Number itmFIBalarm2 "Alarm: [%s]" <alarm> {zwave="2:command=sensor_alarm" }
Number itmFIBlux2 "Lux: [%.2f Lux]" <sun> {zwave="2:command=sensor_multilevel,sensor_type=3"}
Number itmFIBbat2 "Batterie: [%d %%]" <energy> {zwave="2:command=battery"}
Number itmFIBtemp2 "Temperatur: [%.1f °C]" <temperature> {zwave="2:command=sensor_multilevel,sensor_type=1"}
Text item=itmFIBbat2
Text item=itmFIBmotion2
Text item=itmFIBalarm2
Text item=itmFIBlux2
Text item=itmFIBtemp2
And the log:
2016-10-22 14:46:48.887 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 0, ignoring.
2016-10-22 14:46:48.905 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 0, command class = BASIC, value = 0, ignoring.
2016-10-22 14:47:06.012 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 255, ignoring.
2016-10-22 14:47:06.030 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 0, command class = BASIC, value = 255, ignoring.
2016-10-22 14:47:37.088 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 0, ignoring.
2016-10-22 14:47:37.107 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 0, command class = BASIC, value = 0, ignoring.
Any ideas ?
Cheers
Michael
