Hi all,
I’m still having some problems with OH2 and my zwave devices. Specifically two are listed as:
- Node initialising: STATIC_VALUES - both are FGD212 dimmers (node 33 and 34)
openhab security$ grep node33 conf/items/rambert.items
Dimmer FF_BackGarden_Light_Dimmer “Back light [%d %%]” (gExternalLights,gFirstFloor) { channel=“zwave:device:c5ef376d:node33:switch_dimmer” }
Number FF_BackGarden_Light_Power “Back light - current power consumption [%.2f W]” (gPowerSensors,gFirstFloor) { channel=“zwave:device:c5ef376d:node33:meter_watts” }
Number FF_BackGarden_Light_Energy “Back light - total energy use [%.2f KWh]” (gEnergySensors,gFirstFloor) { channel=“zwave:device:c5ef376d:node33:meter_kwh” }
openhab security$ grep node34 conf/items/rambert.items
Switch FF_Hallway_Light “Hallway light [%d %%]” (gFirstFloor,gInternalLights) { channel=“zwave:device:c5ef376d:node34:switch_dimmer” }
Number FF_Hallway_Light_Power “Hallway light - current power consumption [%.2f W]” (gPowerSensors,gFirstFloor) { channel=“zwave:device:c5ef376d:node34:meter_watts” }
Number FF_Hallway_Light_Energy “Hallway light - total energy use [%.2f KWh]” (gEnergySensors,gFirstFloor) { channel=“zwave:device:c5ef376d:node34:meter_kwh” }
One of these things (node33) according to Habmin is linked to two items (FF_BackGarden_Light_Dimmer, GF_Driveway_Light_Dimmer ), which is utterly weird to me, since GF_Driveway_Light_Dimmer is linked to a different thing:
openhab security$ grep GF_Driveway_Light_Dimmer conf/items/rambert.items
Dimmer GF_Driveway_Light_Dimmer “Front light [%d %%]” (gExternalLights,gGroundFloor) { channel=“zwave:device:c5ef376d:node23:switch_dimmer” }
i.e. it’s only linked to node 23:
openhab security$ grep node23 conf/items/rambert.items
Number GF_Driveway_Light_Power “Front light - current power consumption [%.2f W]” (gPowerSensors,gGroundFloor) { channel=“zwave:device:c5ef376d:node23:meter_watts” }
Number GF_Driveway_Light_Energy “Front light - total energy use [%.2f KWh]” (gEnergySensors,gGroundFloor) { channel=“zwave:device:c5ef376d:node23:meter_kwh” }
If I try to unlink node33 from GF_Driveway_Light_Dimmer in Habmin, I get a popup telling me it’s read-only.
My final problem is that when I try to plot a graph as follows:
Chart item=gPowerSensors period=D refresh=300
It only shows “Front light” (twice!) but there should be more:
openhab security$ grep gPowerSensors conf/items/rambert.items
Group gPowerSensors
Number House_Meter_Power “House Power [%.2f kW]” (gPowerSensors) { channel=“zwave:device:c5ef376d:node28:meter_watts” }
Not all of these are in MySQL though, and again I’m totally baffled why:
mysql> select * from Items;
| ItemId | ItemName |
| 1 | Weather_Temp |
| 2 | Weather_Humid |
| 3 | Weather_Pressure |
| 4 | GF_Bathroom_Light |
| 5 | House_Meter_Power |
| 6 | House_Meter_Current |
| 7 | House_Meter_Energy |
| 8 | House_Meter_Voltage |
| 9 | Garage_Siren |
| 10 | FF_BackGarden_Light_Energy |
| 11 | GF_Driveway_Light_Energy |
| 12 | Garage_Inside_Door_Temp |
| 13 | GF_Living_Temp |
| 14 | GF_Living_Humid |
| 15 | GF_Living_Bat |
| 16 | GF_Living_Lumin |
| 17 | GF_Living_UV |
| 18 | GF_Living_Motion |
| 19 | Garage_Inside_Door |
| 20 | Garage_Inside_Door_Bat |
| 21 | FF_LivingRoom_Motion |
| 22 | FF_LivingRoom_Lux |
| 23 | FF_LivingRoom_Bat |
| 24 | FF_BackGarden_Light_Dimmer |
| 25 | FF_Hallway_Light |
| 26 | gInternalLights |
| 27 | FF_LivingRoom_Temp |
| 28 | GF_Driveway_Light_Power |
| 29 | GF_Driveway_Light_Dimmer |
29 rows in set (0.00 sec)
I see quite a few errors in the logfile:
2016-10-05 10:54:29.246 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 34: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=34, callback=219, payload=22 08 60 0D 01 01 59 03 00 01
2016-10-05 10:52:04.144 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 28: Endpoint 4 not found. Cannot set command classes.
2016-10-05 10:46:09.649 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 33: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=33, callback=188, payload=21 08 60 0D 01 01 59 03 00 01
Thanks in advance for any advice!
