Hi folks,
shall I change the label in the properties? I would like to change for example from
Z-Wave Node 4: FGWPE Metered Wall Plug Switch
to
Z-Wave Node 4: Metered Wall Plug Switch (Fridge)
thanks
Andrea
Hi folks,
to
thanks
Andrea
If you want to change it, then change it… There’s no reason to keep the defaults (I also don’t use the default labels).
Thank you
any suggestion regarding the naming convention to use?
thanks again
Andrea
It’s personal preference really. Personally, I use a “location, function (node)” format -:
eg.
Main Bedroom, Lights (Node 5)
