Platform information:
Hardware: PC
OS: Windows 11
Java Runtime Environment: Zulu JDK 17.40.19
openHAB version: 4.0.0 Snapshot
Issue of the topic:
I’m not able to add the RCS TZ45HR to my Openhab System. The Device is in the Database as TZ45, which is slightly different, and I’m not sure if that is why it describes it as an unknown device (ZWave Thing | openHAB).
It recognizes it is a thermostat and creates an XML file with the information I think is correct but I’m not sure (for example, the manufacturer ID is 0x10). This is not a battery-powered device. I am using a
GoControl HUSBZB-1 USB Hub (https://www.amazon.com/dp/B01GJ826F8?psc=1&ref=ppx_yo2ov_dt_b_product_details).
What I did:
- I previously had the stable version and then I tried using the snapshot but nothing changed.
- I reinitialized the device.
- I removed the device from the network and added it again two times (by excluding it properly)
- I restored the device to the factory settings.
I am new to this so I don’t really know well how everything works.
Thank you for the help.
network_c8bc2ef9__node_6.xml (13.1 KB)
