Hardware: Raspberry Pi 3B+ with RaZberry2 (ZMEERAZ2) Z-Wave board
OS: openHABian
Java Runtime Environment: Zulu Embedded OpenJDK Java 8 included in openHABian
openHAB version: 2.4.0
Hi, Can anybody help with integration of switch Warm White/Cold White on ZWA001 (LED Bulb 6: Multi-White)?
I wanna simple switch on Sitemap which can control Warm White/Cold White.
I may be able to research later but the xml file from /var/lib/openhab2/zwave would be helpful. All models have several device identifications and I need to be sure I am looking at the correct database entry.
This folder is mapped to different locations depending on the system on which it is running - I’m not sure wha the system is here, but maybe it’s just in a different place? If not, maybe there is a permission issue such that the binding is unable to create the folder.
Repo install and openHABian is in /var/lib/openhab2/zwave, manual install can be anywhere, but it is recommended in /opt/openhab2, so zwave should be in /opt/openhab2/zwave.
[13:34:35] openhabian@openHABianPi:/$ ls -al /var/lib/openhab2/
total 40
drwxrwxr-x+ 10 openhab openhabian 4096 Aug 3 13:25 .
drwxr-xr-x 33 root root 4096 Aug 3 12:46 …
drwxrwxr-x+ 4 openhab openhab 4096 Aug 3 12:50 cache
drwxrwxr-x+ 5 openhab openhab 4096 Aug 3 13:22 config
drwx------+ 3 openhab openhab 4096 Aug 3 12:48 .config
drwxrwxr-x+ 3 openhab openhabian 4096 Aug 3 12:49 etc
drwxrwxr-x+ 3 openhab openhab 4096 Aug 3 13:04 jsondb
drwxrwxr-x+ 5 openhab openhabian 4096 Aug 3 12:46 persistence
drwxrwxr-x+ 9 openhab openhabian 4096 Aug 3 13:24 tmp
drwxrwxr-x+ 2 openhab openhab 4096 Aug 3 13:37 zwave
Frontail log with two errors during INITIALIZING:
2019-08-03 13:37:35.951 [hingStatusInfoChangedEvent] - ‘zwave:device:94344052:node2’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-08-03 13:37:36.004 [hingStatusInfoChangedEvent] - ‘zwave:device:94344052:node2’ changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
INITIALIZING frontail log:
2019-08-03 13:24:59.691 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:94344052’ changed from UNINITIALIZED to INITIALIZING
2019-08-03 13:24:59.748 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:94344052’ has been updated.
2019-08-03 13:24:59.754 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/ttyAMA0’
2019-08-03 13:24:59.757 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:94344052’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-08-03 13:24:59.789 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-08-03 13:24:59.837 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-08-03 13:24:59.840 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-08-03 13:25:03.855 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:94344052’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-08-03 13:25:03.870 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:94344052’ has been updated.
2019-08-03 13:37:19.996 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@1c6da4c
2019-08-03 13:37:25.399 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:94344052:node2’ to inbox.
2019-08-03 13:37:25.401 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:94344052:node2’ has been added.
2019-08-03 13:37:25.413 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@1012544
2019-08-03 13:37:35.848 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:94344052:node2’ has been removed.
2019-08-03 13:37:35.896 [hingStatusInfoChangedEvent] - ‘zwave:device:94344052:node2’ changed from UNINITIALIZED to INITIALIZING
2019-08-03 13:37:35.910 [hingStatusInfoChangedEvent] - ‘zwave:device:94344052:node2’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-08-03 13:37:35.926 [hingStatusInfoChangedEvent] - ‘zwave:device:94344052:node2’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
2019-08-03 13:37:36.014 [hingStatusInfoChangedEvent] - ‘zwave:device:94344052:node2’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-08-03 13:37:36.021 [hingStatusInfoChangedEvent] - ‘zwave:device:94344052:node2’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-08-03 13:37:36.034 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:94344052:node2’ has been updated.
2019-08-03 13:37:36.049 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:94344052:node2’ has been updated.
2019-08-03 13:37:36.068 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:94344052:node2’ has been updated.
2019-08-03 13:37:36.084 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:94344052:node2’ has been updated.
2019-08-03 13:37:36.101 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
2019-08-03 13:37:36.146 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:94344052:node2’ has been updated.
You don’t have any items linked to those channels, that can’t work of course:
The glue between Things and Items are Links . A Link is an association between exactly one Channel and one Item. If a Channel is linked to an Item, it is “enabled”, which means that the capability the Item represents is accessible through that Channel. Channels may be linked to multiple Items and Items may be linked to multiple Channels.
