i am using the latest snapshot build, fully updated minutes ago…
i cannot get the binding to use security. network key is default. included a garage door opener, its not showing security either. just a ? with a circle around it. what did i miss?
The current snapshot doesn’t currently support security - there’s a dev version which has this and the plan is to merge this into master in the coming few weeks.
I’m not sure what you mean - there is only the JAR on the marketplace. You can install it either from the marketplace, or with the JAR in the security thread.
