Hey @chris
I deleted a thing and readded it … now some meter stuff stopped working and the log shows “not the right scale”.
can you help me out there? device: http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/1
17:41:35.219 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 02 0E 32 02 21 34 00 00 00 01 00 00 00 00 00 00 C7
17:41:35.226 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
17:41:35.231 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 02 0E 32 02 21 34 00 00 00 01 00 00 00 00 00 00 C7
17:41:35.234 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 14 00 04 00 02 0E 32 02 21 34 00 00 00 01 00 00 00 00 00 00 C7
17:41:35.238 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 02 0E 32 02 21 34 00 00 00 01 00 00 00 00 00 00
17:41:35.240 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Application Command Request (ALIVE:DONE)
17:41:35.242 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Starting initialisation from DONE
17:41:35.244 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@b0754c already registered
17:41:35.246 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Incoming command class METER
17:41:35.264 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 2: Received METER command V3
17:41:35.273 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 2: Meter: Type=Electric(1), Scale=W(2), Value=0.1
17:41:35.273 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 02 03 25 03 FF 2A
17:41:35.275 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
17:41:35.280 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveMeterValueEvent
17:41:35.283 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 0.1
17:41:35.285 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:15348538564:node2:meter_watts to 0.1 [DecimalType]
17:41:35.318 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_Power_Factor <> E_W
17:41:35.319 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_KWh <> E_W
17:41:35.320 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_A <> E_W
17:41:35.322 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_V <> E_W
