After months of bashing my head against a wall trying to get z-wave working, and reading thousands of pages on it, I’m finally reaching out to try to get some help.
I’m running OpenHab2 on my Raspberry Pi 3 with a Razberry z-wave hat,
After playing with all the usual suspects (serial port stuff) I seem to have the Razberry hat talking to openHAB (could anyone have come up with a more difficult of convoluted set of steps needed to do that???)
What I can’t seem to do though is pair any devices to it. When I search to add devices through OpenHab2 it asks me to choose a binding, I choose z-wave, it then sits searching for about 30 seconds, during that time, the red light appears on the Razberry hat indicating inclusion mode, but it never sees any devices. I have tried it with a z-wave LED bulb, a z-wave motion sensor, and a z-wave plug in dimmer module, all of these devices can be included and excluded on a different z-wave hub, but none show up at all in any search on the OpenHab setup.
What am I missing here?
events.log:
2017-11-10 23:41:57.538 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:4d725078' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2017-11-10 23:42:17.564 [BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@1d6b7e0
2017-11-10 23:42:47.651 [BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@185d488
2017-11-10 23:42:53.873 [BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@2ba186
2017-11-10 23:43:23.952 [BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@1929c4a
2017-11-10 23:46:20.803 [BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@1ba7350
2017-11-10 23:46:50.872 [BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@17d8ed7
openhab.log
2017-11-10 23:41:53.569 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyAMA0'
2017-11-10 23:41:53.596 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2017-11-10 23:41:53.598 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2017-11-10 23:41:53.626 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2017-11-10 23:41:53.627 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2017-11-10 23:41:56.765 [WARN ] [ve.internal.protocol.ZWaveController] - TODO: Implement processing of Request Message = -- (0x0A)
2017-11-10 23:41:57.102 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-10 23:41:57.104 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-10 23:41:57.105 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-10 23:41:57.106 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-10 23:41:57.108 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 1
2017-11-10 23:41:57.109 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
