parameters 61 and 62
that would enable to set the color of the led ring of the plug via a rule
If you give me a hint what channel I should use ā¦ I would add these under Configuration in the DB.
Cheers
Sorry Iāve not had the chance to look at this - I had a long flight delay returning from the USA and only got home yesterday afternoon but will take a look today.
Let me guessā¦ United ā¦ I always have huge delays from/to US with them ā¦
No - it was British Airways. Apparently the tail was damaged when it landed at Heathrow so they had to find a replacement aircraft which took nearly 24 hoursā¦
Iāve updated the exporter to generate custom channels so that we can re-use the options in the parameter configurations. Iām not sure this is really used by UIs, but itās there all the sameā¦
Iāve just kicked off a new build which should be complete in about 30 minutes - let me know how it worksā¦
for a quick test I added it on the UI
WORKS LIKE A CHARM
For people stumbling over thisā¦ this might save a minute:
Selection item=zwave_device_15348538564_node8_config_decimal_param61 label="LED ON" mappings=[0=Steps_Watts, 1=Continous_Watts, 2=White, 3=Red, 4=Green, 5=Blue, 6=Yellow, 7=Cyan, 8=Magenta, 9=Off]
Selection item=zwave_device_15348538564_node8_config_decimal_param62 label="LED OFF" mappings=[0=LastPowerStep, 1=White, 2=Red, 3=Green, 4=Blue, 5=Yellow, 6=Cyan, 7=Magenta, 8=Off]
Thnx chris
I still donāt unterstand which Channel I need to use.
I tried both {channel="zwave:device:bridge:node10:config:decimal:param2"}
and {channel="zwave:device:bridge:node10:config_1_2"}
in my items file. Of course, none of them worked.
I honestly have no idea where to get that channel from? PaperUI only shows the normal non-configuration channels like āBrightnessā and āStateā.
Thank you for any ideas.
I think you talk about another device. Not the fibaro plug.
If the parameter was not added as a channel in the DB this wont work.
True, I was hoping this was something universally usable.
Looks like I have to stick with the REST call for now. Thanks.
Or add the desired to the Database if from General interest to many other users
I will try and do this as soon as I have the real need. I just wanted to understand what is going on. Donāt have a device like this, yet.
Hello
Should this work?
I receive the warning
00:48:57.773 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 73: Command for unknown channel zwave:device:02fc84a6:node73:scene_number with DecimalType
My item
Number EG_Gang_RGB_Scene "Licht Szene" <colorlight> (gEG_Gang, gEG_Gang_RGB, gLights) {channel="zwave:device:02fc84a6:node73:scene_number"}
Yes, but you have to activate the scenes in your switch (only works with FGS223/213, not with the 222):
HABmin -> select node -> Configuration Parameters -> ser Parameter 28 and 29 to 15 (=all scene numbers).
You are then able to trigger in your rules on scene numbers:
//Switch 1 1xclick=1.0 ,2xclick=1.3,3xclick=1.4,press and hold=1.1
//Switch 2 1xclick=2.0 ,2xclick=2.3,3xclick=2.4,press and hold=2.1
rule "test scenes"
Item EG_Gang_RGB_Scene received update 1.1 // or one of the other scene numbers
// do stuff
Edit: okay, this thread is about the RGBW controller, sorry ā¦
Hi guys!
I read through most of the relevant threads - still canāt get it working with a Fibaro RGBW Dimmer:
Number varAnimation_LedCouch "Programm LED Couch" <settings> (gAutorules) {channel="zwave:device:fakeNUMBER:node50:scene_number_param72"}
Used within rule:
rule "Alarmanlage"
when Item gAlarms changed from OFF to ON then
if (varAlarmanlage.state == ON) {
sendNotification("mail@domain.com","Alarmanlage ausgelƶst")
sendNotification("mail@domain2.com","Alarmanlage ausgelƶst")
sendMail(mailToMe,"Alarmanlage ausgelƶst", "Alarmanlage ausgelƶst")
sendCommand(varAnimation_LedCouch,10)
Also tried to change the parameter manually via Habmin - no luck -any ideas?
Regards,
Herbert
Dear Community,
How can I change parameter from rules without using sendHttpPutRequest, because there will be no wifi in the area ?
Eclipse doesnāt provide functionality to do this unfortunately.
We can create channels in the database for parameters that are routinely required to be changed, so if you have a good use case we can add a channel.
Like in fibaro rgbw, I want to set parameter 11 to different period based on some events and time ?
