True, I was hoping this was something universally usable.
Looks like I have to stick with the REST call for now. Thanks.
Or add the desired to the Database if from General interest to many other users
I will try and do this as soon as I have the real need. I just wanted to understand what is going on. Donât have a device like this, yet.
Hello
Should this work?
I receive the warning
00:48:57.773 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 73: Command for unknown channel zwave:device:02fc84a6:node73:scene_number with DecimalType
My item
Number EG_Gang_RGB_Scene "Licht Szene" <colorlight> (gEG_Gang, gEG_Gang_RGB, gLights) {channel="zwave:device:02fc84a6:node73:scene_number"}
Yes, but you have to activate the scenes in your switch (only works with FGS223/213, not with the 222):
HABmin -> select node -> Configuration Parameters -> ser Parameter 28 and 29 to 15 (=all scene numbers).
You are then able to trigger in your rules on scene numbers:
//Switch 1 1xclick=1.0 ,2xclick=1.3,3xclick=1.4,press and hold=1.1
//Switch 2 1xclick=2.0 ,2xclick=2.3,3xclick=2.4,press and hold=2.1
rule "test scenes"
Item EG_Gang_RGB_Scene received update 1.1 // or one of the other scene numbers
// do stuff
Edit: okay, this thread is about the RGBW controller, sorry âŠ
Hi guys!
I read through most of the relevant threads - still canât get it working with a Fibaro RGBW Dimmer:
Number varAnimation_LedCouch "Programm LED Couch" <settings> (gAutorules) {channel="zwave:device:fakeNUMBER:node50:scene_number_param72"}
Used within rule:
rule "Alarmanlage"
when Item gAlarms changed from OFF to ON then
if (varAlarmanlage.state == ON) {
sendNotification("mail@domain.com","Alarmanlage ausgelöst")
sendNotification("mail@domain2.com","Alarmanlage ausgelöst")
sendMail(mailToMe,"Alarmanlage ausgelöst", "Alarmanlage ausgelöst")
sendCommand(varAnimation_LedCouch,10)
Also tried to change the parameter manually via Habmin - no luck -any ideas?
Regards,
Herbert
Dear Community,
How can I change parameter from rules without using sendHttpPutRequest, because there will be no wifi in the area ?
Eclipse doesnât provide functionality to do this unfortunately.
We can create channels in the database for parameters that are routinely required to be changed, so if you have a good use case we can add a channel.
Like in fibaro rgbw, I want to set parameter 11 to different period based on some events and time ?
