Continuing on my zwave error,
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/168
I show you the result when I open and close the door. Motion and door contact are not updated.
Thank you Chris
01 18 06 31 05 01 0A 00 53 6F
2016-09-03 14:19:37.051 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-09-03 14:19:37.053 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 24 00 04 00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 07 08 00 05 31 05 03 01 18 06 31 05 01 0A 00 53 6F
2016-09-03 14:19:37.055 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 24 00 04 00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 07 08 00 05 31 05 03 01 18 06 31 05 01 0A 00 53 6F
2016-09-03 14:19:37.058 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 07 08 00 05 31 05 03 01 18 06 31 05 01 0A 00 53
2016-09-03 14:19:37.059 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Application Command Request (INITIALIZING:PING)
2016-09-03 14:19:37.060 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 12: Node is ALIVE. Init stage is PING.
2016-09-03 14:19:37.062 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent
2016-09-03 14:19:37.063 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2016-09-03 14:19:37.064 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Setting ONLINE
2016-09-03 14:19:37.068 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Node Status event during initialisation - Node is ALIVE
2016-09-03 14:19:37.070 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Node advancer - PING: queue length(0), free to send(true)
2016-09-03 14:19:37.071 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Node advancer: loop - PING try 1: stageAdvanced(false)
2016-09-03 14:19:37.072 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Node advancer: PING - send NoOperation
2016-09-03 14:19:37.073 [DEBUG] [ndclass.ZWaveNoOperationCommandClass] - NODE 12: Creating new message for command No Operation
2016-09-03 14:19:37.074 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Node advancer - queued packet. Queue length is 1
2016-09-03 14:19:37.076 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Putting message SendData in wakeup queue.
2016-09-03 14:19:37.077 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 12: Node Status event - Node is ALIVE
2016-09-03 14:19:37.078 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Incoming command class MULTI_CMD
2016-09-03 14:19:37.079 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Received Multi-Command Request
2016-09-03 14:19:37.080 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class BATTERY
2016-09-03 14:19:37.080 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:37.081 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 12: Received Battery Request
2016-09-03 14:19:37.082 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 12: Battery report value = 100
2016-09-03 14:19:37.082 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-09-03 14:19:37.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-09-03 14:19:37.084 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
2016-09-03 14:19:37.084 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:battery-level to 100 [DecimalType]
2016-09-03 14:19:37.087 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: CC event during initialisation stage IDLE
2016-09-03 14:19:37.088 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class ALARM
2016-09-03 14:19:37.088 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:37.090 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Received Alarm Request V3
2016-09-03 14:19:37.091 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Process Alarm Report, V3, length 33
2016-09-03 14:19:37.092 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Alarm report - 7 = 0, sensor=0, event=8, status=255
2016-09-03 14:19:37.093 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Alarm Type = Burglar (7)
2016-09-03 14:19:37.093 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2016-09-03 14:19:37.094 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2016-09-03 14:19:37.095 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2016-09-03 14:19:37.097 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:alarm_burglar to OFF [OnOffType]
2016-09-03 14:19:37.098 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class SENSOR_MULTILEVEL
2016-09-03 14:19:37.099 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:37.099 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Received SENSOR_MULTILEVEL command V5
2016-09-03 14:19:37.100 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Multi Level REPORT received
2016-09-03 14:19:37.100 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Type = Luminance(3), Scale = 0
2016-09-03 14:19:37.101 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Value = 24
2016-09-03 14:19:37.102 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:37.103 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:37.104 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 24
2016-09-03 14:19:37.105 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:sensor_luminance to 24 [DecimalType]
2016-09-03 14:19:37.106 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class SENSOR_MULTILEVEL
2016-09-03 14:19:37.107 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:37.109 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Received SENSOR_MULTILEVEL command V5
2016-09-03 14:19:37.109 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Multi Level REPORT received
2016-09-03 14:19:37.110 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Type = Temperature(1), Scale = 1
2016-09-03 14:19:37.111 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Value = 83
2016-09-03 14:19:37.112 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:37.114 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:37.115 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 83
2016-09-03 14:19:37.116 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 12: Sensor is reporting scale 1, requiring conversion to 0. Value is now 83.
2016-09-03 14:19:37.116 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 83F to 28.3C
2016-09-03 14:19:37.117 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:sensor_temperature to 28.3 [DecimalType]
2016-09-03 14:19:37.118 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 19: Transaction not completed: node address inconsistent. lastSent=19, incoming=255
2016-09-03 14:19:37.916 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 24 00 04 00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 1C 06 31 05 01 0A 00 53 74
2016-09-03 14:19:37.930 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-09-03 14:19:37.932 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 24 00 04 00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 1C 06 31 05 01 0A 00 53 74
2016-09-03 14:19:37.933 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 24 00 04 00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 1C 06 31 05 01 0A 00 53 74
2016-09-03 14:19:37.935 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 1C 06 31 05 01 0A 00 53
2016-09-03 14:19:37.936 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Application Command Request (ALIVE:DETAILS)
2016-09-03 14:19:37.936 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Incoming command class MULTI_CMD
2016-09-03 14:19:37.937 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Received Multi-Command Request
2016-09-03 14:19:37.937 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class BATTERY
2016-09-03 14:19:37.939 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:37.939 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 12: Received Battery Request
2016-09-03 14:19:37.940 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 12: Battery report value = 100
2016-09-03 14:19:37.940 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-09-03 14:19:37.941 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-09-03 14:19:37.941 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
2016-09-03 14:19:37.942 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:battery-level to 100 [DecimalType]
2016-09-03 14:19:37.943 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class ALARM
2016-09-03 14:19:37.943 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:37.944 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Received Alarm Request V3
2016-09-03 14:19:37.944 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Process Alarm Report, V3, length 33
2016-09-03 14:19:37.945 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Alarm report - 6 = 0, sensor=0, event=22, status=255
2016-09-03 14:19:37.946 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Alarm Type = Access Control (6)
2016-09-03 14:19:37.946 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2016-09-03 14:19:37.947 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2016-09-03 14:19:37.948 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2016-09-03 14:19:37.949 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:alarm_access to OFF [OnOffType]
2016-09-03 14:19:37.952 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class SENSOR_MULTILEVEL
2016-09-03 14:19:37.953 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:37.954 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Received SENSOR_MULTILEVEL command V5
2016-09-03 14:19:37.954 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Multi Level REPORT received
2016-09-03 14:19:37.955 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Type = Luminance(3), Scale = 0
2016-09-03 14:19:37.955 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Value = 28
2016-09-03 14:19:37.956 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:37.956 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:37.957 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 28
2016-09-03 14:19:37.958 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:sensor_luminance to 28 [DecimalType]
2016-09-03 14:19:37.959 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class SENSOR_MULTILEVEL
2016-09-03 14:19:37.959 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:37.965 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Received SENSOR_MULTILEVEL command V5
2016-09-03 14:19:37.965 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Multi Level REPORT received
2016-09-03 14:19:37.966 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Type = Temperature(1), Scale = 1
2016-09-03 14:19:37.967 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Value = 83
2016-09-03 14:19:37.974 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:37.974 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:37.975 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 83
2016-09-03 14:19:37.976 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 12: Sensor is reporting scale 1, requiring conversion to 0. Value is now 83.
2016-09-03 14:19:37.976 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 83F to 28.3C
2016-09-03 14:19:37.977 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:sensor_temperature to 28.3 [DecimalType]
2016-09-03 14:19:37.978 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 19: Transaction not completed: node address inconsistent. lastSent=19, incoming=255
2016-09-03 14:19:38.879 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 24 00 04 00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 17 00 05 31 05 03 01 16 06 31 05 01 0A 00 53 7F
2016-09-03 14:19:38.885 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-09-03 14:19:38.887 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 24 00 04 00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 17 00 05 31 05 03 01 16 06 31 05 01 0A 00 53 7F
2016-09-03 14:19:38.889 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 24 00 04 00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 17 00 05 31 05 03 01 16 06 31 05 01 0A 00 53 7F
2016-09-03 14:19:38.891 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 17 00 05 31 05 03 01 16 06 31 05 01 0A 00 53
2016-09-03 14:19:38.891 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Application Command Request (ALIVE:DETAILS)
2016-09-03 14:19:38.892 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Incoming command class MULTI_CMD
2016-09-03 14:19:38.892 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Received Multi-Command Request
2016-09-03 14:19:38.893 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class BATTERY
2016-09-03 14:19:38.894 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:38.894 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 12: Received Battery Request
2016-09-03 14:19:38.895 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 12: Battery report value = 100
2016-09-03 14:19:38.895 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2016-09-03 14:19:38.896 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2016-09-03 14:19:38.896 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
2016-09-03 14:19:38.897 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:battery-level to 100 [DecimalType]
2016-09-03 14:19:38.898 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class ALARM
2016-09-03 14:19:38.899 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:38.901 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Received Alarm Request V3
2016-09-03 14:19:38.901 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Process Alarm Report, V3, length 33
2016-09-03 14:19:38.902 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Alarm report - 6 = 0, sensor=0, event=23, status=255
2016-09-03 14:19:38.903 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 12: Alarm Type = Access Control (6)
2016-09-03 14:19:38.903 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2016-09-03 14:19:38.904 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2016-09-03 14:19:38.904 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2016-09-03 14:19:38.905 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:alarm_access to OFF [OnOffType]
2016-09-03 14:19:38.906 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class SENSOR_MULTILEVEL
2016-09-03 14:19:38.907 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:38.911 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Received SENSOR_MULTILEVEL command V5
2016-09-03 14:19:38.913 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Multi Level REPORT received
2016-09-03 14:19:38.914 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Type = Luminance(3), Scale = 0
2016-09-03 14:19:38.915 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Value = 22
2016-09-03 14:19:38.917 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:38.918 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:38.919 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 22
2016-09-03 14:19:38.920 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:sensor_luminance to 22 [DecimalType]
2016-09-03 14:19:38.921 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Incoming command class SENSOR_MULTILEVEL
2016-09-03 14:19:38.921 [DEBUG] [dclass.ZWaveMultiCommandCommandClass] - NODE 12: Calling handleApplicationCommandRequest.
2016-09-03 14:19:38.927 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Received SENSOR_MULTILEVEL command V5
2016-09-03 14:19:38.927 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Multi Level REPORT received
2016-09-03 14:19:38.928 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Type = Temperature(1), Scale = 1
2016-09-03 14:19:38.929 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Sensor Value = 83
2016-09-03 14:19:38.930 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2016-09-03 14:19:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 83
2016-09-03 14:19:38.932 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 12: Sensor is reporting scale 1, requiring conversion to 0. Value is now 83.
2016-09-03 14:19:38.933 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 83F to 28.3C
2016-09-03 14:19:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Updating channel state zwave:device:161955dc:node12:sensor_temperature to 28.3 [DecimalType]
