Hello all…using a pi b 3+, latest openhabian image.
I use a gen5 zwave stick, I know it uses the port dev/tty/ACM0, but that port is not listed as a choice in paper ui. Where is the config file to set this manually?
First of all does dmesg confirm the OS sees the stick on that port? If you have other USB devices the port could be different.
Did you follow the serial port binding docs for modifying the Java options? That is not usually needed now but may help.
Yes, that turned out to be the issue. The line for the extra ports was commented out in the config file. Appreciate the help.
