chris
(Chris Jackson)
August 30, 2017, 2:07pm
41
Alexus1211:
This is correct, but that is not what I wrote in my original post. I wrote that Endpoint1 behaves exactly like Endpoint0, which it should not be the case, right?
Sorry - I misread that. Probably it is not right and looking at the manual it is incorrect.
datsac
(dcp_devel)
August 30, 2017, 3:00pm
42
@Alexus1211 I’m sorry but I don’t have an external relay yet.
datsac
(dcp_devel)
August 30, 2017, 8:21pm
43
Maybe It’s necessary to change endpoints IDs in zwave database ( endpoint 0 renamed to 1 , 1 to 2 and 2 to 3).
Please do not do this as it’s likely to cause (big!) problems.
@chris Ok, Bad idea about changing endpoints ids.
Because I don’t have any relay i can’t see the behaviors explined by @Alexus1211
In reference to the status updates for our qubino smartmeter, maybe the problem is related to this post
I have seen your post previously and have also tried that, probably followed every reasonable suggestion in the forum in over 40 include/exclude etc. attempts. I also have Z Stick Gen5 and also am only using the Switch1/2 channels, not the “legacy” ones. In an earlier releases I at least had a Flush 1 Relay working (but this only was because I used the legacy channel), now it doesn’t work anymore either. Part of the problem is regression related, I am pretty sure about that (bugs introduced in …
As Allen explains, in the channel settings of the device, Association group field generally is blank, and if I try to add the controller to Group 1 / Lifeline it vanishes again at some point.
With no lifeline association with controller, updates are not going to work…??
chris
(Chris Jackson)
August 30, 2017, 8:36pm
44
datsac:
Status updates for Qubino Relays/Dimmers generally do not work
Yes - I meant to comment on that, but I think this is likely. I hope to look at this issue shortly.
@chris
Hi Chris, any update on the Qubino issue?
chris
(Chris Jackson)
September 14, 2017, 6:48am
46
No - I do now have a switch to play with and I hope to look at it over the weekend.
chris
(Chris Jackson)
September 16, 2017, 6:22pm
47
Please note that a fix will likely only be added to the development binding -:
The latest version of the development binding dated 8th Sep 2018 is here .
Toward the end of last year I spent some time doing some initial refactoring of the ZWave binding in OH2. This focussed on rewriting the way transactions work as this is an enabler for other areas of the code. At the same time I also restructured the different layers of the binding to make things cleaner, and done some changes to support a system of autocoding the command classes directly from the Z-Wave standard which s…
At least initial testing will be done here and then I’ll have to see if it can be retro fitted (probably not as it’s quite a lot of changes).
What’s the best parameter to use with a Razberry? To me is working half good, I mean after 10 minuts, I don’t get measures anymore, may be has to be set some params?
Roman1
(Roman)
January 24, 2021, 9:05am
50
Hello every one.
Any updates on this topic?
Does any one succeeded to control External relays?
I got the same issue. The firmware version of the Smart Meter is “S7”
